Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: YafaRay rendering plug-in |
| Print at Sep 14, 2026, 7:25:34 AM |
| Posted by SeppoV12 at Feb 18, 2022, 6:33:44 PM |
Re: YafaRay rendering plug-in The resulting non-crashing render does have some texture or surface clipping issues (and I've noticed it on many other models from 3dWareHouse as well). Probably you have already noticed that making 'material' (just above material 0 in Model materials list of Denon), material 12 and material 13 invisible will remove most of that surface clipping. Reason for clipping seems to be that model has different color/material on inner surface and outer (visible) surface. At some angle the phenomenon appears as the inner color leaks through. |
| Posted by Puybaret at Feb 25, 2022, 4:18:22 PM |
Re: YafaRay rendering plug-in The version 1.4.5 fixes crashes that may happen with DAE models specifying only transparent color for some of its effect / material (generally edges like reported by mickut). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Jul 18, 2022, 11:21:50 PM |
Re: YafaRay rendering plug-in For your information, YafaRay renderer is now available in Sweet Home 3D 7.0 making this plug-in useful only if you use an older of Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 14, 2026, 7:25:34 AM |
