Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: YafaRay rendering plug-in |
| Print at Sep 14, 2026, 6:52:22 AM |
| Posted by Puybaret at Jul 31, 2020, 3:02:57 PM |
Re: YafaRay rendering plug-in Thanks Cecilia for your nice test + the music, and sorry for the stupid bug I left in the version 1.3 of the plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Xiste at Jul 31, 2020, 5:13:17 PM |
Re: YafaRay rendering plug-in @Puybaret: I confirm that this works. Thank you for your efforts! @Ceciliabr: Catchy music! ... and an awesome rendering. |
| Posted by GhyslainB at Aug 2, 2020, 12:26:38 PM |
Re: YafaRay rendering plug-in Not sure if the question is more for Emmanuel @Puybaret or for @enkonyito, but here it goes: I've tried to use Yafaray (version 1.3.2) with the PhotoVideoRendering plugin (version 2.0) to render a series of images. When I click start in the plugin window, nothing seems to happen, but the console fills in with the now familiar Boost library error messages (copied below). There seems to be a reference to tmp files in ~/Library/Application Support... would this be something on my end or a bug similar to the previous one affecting the plugin? Thanks! Exception in thread "pool-14-thread-1" java.lang.UnsatisfiedLinkError: /Users/Ghyslain/Library/Application Support/eTeks/Sweet Home 3D/work/6400-53cf3a27-5558-44aa-8227-8989291c3488/dll3844500745242148772tmp/libyafaray_v3_core.dylib: dlopen(/Users/Ghyslain/Library/Application Support/eTeks/Sweet Home 3D/work/6400-53cf3a27-5558-44aa-8227-8989291c3488/dll3844500745242148772tmp/libyafaray_v3_core.dylib, 1): Library not loaded: /usr/local/opt/boost/lib/libboost_system.dylib |
| Posted by enkonyito at Aug 2, 2020, 3:05:57 PM |
Re: YafaRay rendering plug-in Not sure if the question is more for Emmanuel @Puybaret or for @enkonyito, but here it goes: I've tried to use Yafaray (version 1.3.2) with the PhotoVideoRendering plugin (version 2.0) to render a series of images. GhyslainB, try this version of the PhotoVideoRendering plug-in. ---------------------------------------- EnkoNyito |
| Posted by ssandison at Sep 21, 2020, 3:29:27 PM |
Re: YafaRay rendering plug-in This is a great plugin. I always use it. The only thing I'm wondering is that if you need to do multiple images and they take a long time to render could there be a feature where you setup various shots based on stored view points and set where the images should save and what settings etc. Then you could leave the machine unattended to work through the renders rather than needed to go back and check. Sometimes I'm rendering overnight so that would be an amazing feature for me. |
| Posted by Puybaret at Sep 25, 2020, 11:45:00 PM |
Re: YafaRay rendering plug-in See the answer of EnkoNyito just above your question. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wilx at Sep 29, 2020, 8:37:08 PM |
Re: YafaRay rendering plug-in I'm unfortunately having issues trying to run the YafaRay plugin on Mac - getting a "developer cannot be verified" error, which persists no matter what my app permissions are. I've tried lots of things but not managed to get any luck... |
| Posted by gsnake69 at Oct 11, 2020, 5:07:41 PM |
Re: YafaRay rendering plug-in I cannot run this plugin on my MacbookPro with Catalina 10.15.7. The first time I run the plugin it shows the following error "“libboost_system.dylib” cannot be opened because the developer cannot be verified.macOS cannot verify that this app is free from malware.SweetHome3D created this file today at 14:54.". I'm running the Mac App Store version of sh3d. How can I make MacOS understand that these files are safe ? Thanks. |
| Posted by Puybaret at Oct 11, 2020, 10:28:02 PM |
Re: YafaRay rendering plug-in wilx, gsnake69, I wouldn't be astonished that Apple decided to forbid to run some .dylib dynamic libraries imported in a sandboxed program. Does it work with the free version? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by gsnake69 at Oct 12, 2020, 12:47:38 AM |
Re: YafaRay rendering plug-inJust tested it and it works in the free version .... |
Current timezone is GMT Sep 14, 2026, 6:52:22 AM |
