Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Doors in plan are stretched out. |
| Print at Sep 19, 2026, 3:39:00 PM | |
| Posted by Ferraro at Aug 14, 2019, 1:06:39 AM |
Doors in plan are stretched out. I recently upgraded from 4.2 to 6.2, and found the doors in my library that are using cut out shapes are not showing correctly in plan view. Instead of the normal white box that displays over the wall, I get a really long stretched out box that is at least 20 times the size it should be hanging way outside my actual plan. This happens on all my door and windows with custom cut out shapes. This is an example of what I have in the properties file. doorOrWindowCutOutShape#1=M0,0v84.25h36v-84.25zLooks fine in 3D view, but plan view is ruined. Any ideas what is causing this? Is there another setting I must add for custom cut outs since 4.2? |
| Posted by Ferraro at Aug 14, 2019, 9:01:25 PM |
Re: Doors in plan are stretched out. So, to answer my own question for the sake of those interested. The SVG path dimensions were calculated in inches previously, which worked fine in older versions. I multiplied all the dimensions by 2.54, and they are now working fine... doorOrWindowCutOutShape#1=M0,0v84.25h36v-84.25zis now: doorOrWindowCutOutShape#1=M0,0v213.995h91.44v-213.995z |
Current timezone is GMT Sep 19, 2026, 3:39:00 PM |
