Print at Aug 20, 2026, 6:58:31 AM
Posts: 33   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Posted by Bubblobill at Aug 3, 2019, 6:08:55 PM
Re: Streets and Roads
Check out the mini-golf holes . The same principle applies.
Posted by KitchM at Aug 4, 2019, 10:15:55 PM
@bdfd, please supply a link to your projects. I don't know where your examples are.
Also, everyone, I cannot see the pavement texture with the dotted line anywhere but on my button bar. However, when I select it, nothing happens and I cannot add it to the item I'm editing.
Posted by VeroniQ at Aug 4, 2019, 10:41:08 PM
KitchM, draw a line before with Create Polylines tool.
Posted by Mike53 at Aug 4, 2019, 10:49:11 PM
You could download the latest library files, version 1.7 i think. it contains road lines
or
apply the gray pavement texture then draw walls where you want lines, 100 mm wide 2mm high color both sides white
Posted by KitchM at Aug 4, 2019, 11:20:01 PM
Okay, please help me clarify this. If I am creating a road or a driveway, is it a room, a series of walls or a set of polylines?
Posted by Mike53 at Aug 5, 2019, 12:04:35 AM
The room you create will actually end up being your road or driveway. poly lines do not show up in the 3d view and i am not sure if they print, all you need is a room, walls may help you to create the room, but then they can be deleted
Posted by KitchM at Aug 5, 2019, 12:37:48 AM
Okay. So I create a room. Let's say it is a rectangle. I therefore see a rectangle shaded with grey inside.
Next I would add arcs to create a curve to my "room". Where and how is it exactly that I create an arc?
Posted by VeroniQ at Aug 5, 2019, 3:03:54 AM
Polyline is only for the dotted lines. They can be visible in 3D if you choose the option.
If you want a curved street, you have to draw walls before, curve them, then create a room into the joined walls and remove walls. Then apply a texture to the room.
If you need rectangular street, use only Create rooms tool the apply a texture.
Posted by KitchM at Aug 5, 2019, 4:24:00 AM
Good so far. Now how do I turn the walls into a room?
Posted by UbuntuBirdy at Aug 5, 2019, 6:53:46 AM
You can not turn the walls inti rooms.
You should use the walls to define the perimeter of the room you want to create, to "draw" the shape of the room.
Once you have done that, you can choose the room tool and double click into that shape and your room will automaticly be created.
Pascal
