Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Can't Run Sweet Home 3D |
| Print at Sep 6, 2026, 6:23:54 AM | |
| Posted by Oak at Jan 18, 2008, 10:35:00 PM |
Can't Run Sweet Home 3D Both the web version and installation does not work for me: Web: http://sweethome3d.sourceforge.net/SweetHome3D.jnlp does not have execute permission ... please fix Local installation on OpenSUSE 10.3: @linux:~/Sys/Install/SweetHome3D-1.2> ./SweetHome3D java: xcb_xlib.c:52: xcb_xlib_unlock: Assertion `c->xlib.lock' failed. ./SweetHome3D: line 1: 16934 Neúspěšně ukončen (SIGABRT) jre1.6.0_03/bin/java -classpath lib/SweetHome3D.jar:lib/Loader3DS1_2.jar:lib/itext-2.0.4.jar:lib/j3dcore.jar:lib/j3dutils.jar:lib/vecmath.jar:jre1.6.0_03/lib/javaws.jar -Djava.library.path=lib -Xmx192m com.eteks.sweethome3d.SweetHome3D ...this problem persist even after updating to lates Java 1.6.0. Any suggestions? Regards, Oak [Note: this thread was started on sourceforge.net forums] |
| Posted by Oak at Jan 18, 2008, 11:00:00 PM |
Re: Can't Run Sweet Home 3D Resolved the web start issue: # su (or sudo) # ln /usr/lib/jvm/java-1.6.0.u1-sun-1.6.0.u1/jre/bin/javaws /usr/bin/javaws ...and then run: javaws http://sweethome3d.sourceforge.net/SweetHome3D.jnlp ...and it works! The original javaws had 0kb size. That was probably the problem. Please, help me to resolve the intall issue. Regards, Oak |
| Posted by Oak at Jan 18, 2008, 11:02:00 PM |
Re: Can't Run Sweet Home 3D Now, the web version says: 3D Error Sweet Home 3D will exit now because of a fatal error in 3D rendering system. Regards, Oak |
| Posted by Puybaret at Jan 18, 2008, 11:09:00 PM |
Re: Can't Run Sweet Home 3D The "fatal error in 3D rendering system" means that you have to upgrade your video card driver. Sorry, I can't you tell you more than that... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Randal_Lovelace at Mar 8, 2008, 12:18:00 AM |
Re: Can't Run Sweet Home 3D This error CAN NOT be a video card driver issue as I get the same issue and have the latest (nightly updated) drivers for EVERYTHING on my system. - This error needs fixing as it is apparent that a lot of individuals running different OS are getting this error. |
| Posted by Randal_Lovelace at Mar 9, 2008, 6:17:00 PM |
Re: Can't Run Sweet Home 3D [root@localhost randal]# ln /usr/lib/jvm/java-1.6.0.u1-sun-1.6.0.u1/jre/bin/javaws /usr/bin/javaws ln: accessing `/usr/lib/jvm/java-1.6.0.u1-sun-1.6.0.u1/jre/bin/javaws': No such file or directory [root@localhost randal]# hmm no such thing here... interesting... |
Current timezone is GMT Sep 6, 2026, 6:23:54 AM |
