Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How could I make a window see-through |
| Print at Sep 14, 2026, 8:09:35 AM | |
| Posted by MichaelN at Jul 9, 2019, 10:14:51 PM |
How could I make a window see-through I have found a model of a velux window in the web, but I can't see-trough in the 3D view. I tried to make it to a window with the FurnitureLibraryEditor, but with no effect. What could I do? The PluginFurnitureCatalog.properties contains now these lines: name#1=Velux category#1=Türen und Fenster icon#1=/Velux.png model#1=/Velux/Velux.obj multiPartModel#1=true width#1=89 depth#1=116.21289 height#1=111.77972 movable#1=true doorOrWindow#1=true doorOrWindowCutOutShape#1=M0,0 v1 h1 v-1 z elevation#1=80 modelSize#1=50902 horizontallyRotatable#1=false |
| Posted by Mike53 at Jul 9, 2019, 10:23:54 PM |
Re: How could I make a window see-through hi Michael i dont think any of the details relate to the texture properties of the of, only its position, size etc. if you use the 3d view>export to obj function, after choose where to save it, you will see 2 files, a .obj and a .mtl... it is the .mtl file you would need to modify. Mike |
| Posted by MichaelN at Jul 9, 2019, 10:26:13 PM |
Re: How could I make a window see-through OK, I understand the issue... The see-through-option only works on walls. And I designed my roof as a kind of furniture. So I think I need a cut out in my window-furniture? |
| Posted by Mike53 at Jul 9, 2019, 10:49:02 PM |
Re: How could I make a window see-through export your velux....import as window... put a tick in the checkbox during the import..... create you wall.. position your velux.... export wall and velux....import....tilt.... Like this |
| Posted by MichaelN at Jul 9, 2019, 10:56:31 PM |
Re: How could I make a window see-through so simple... |
| Posted by Mike53 at Jul 9, 2019, 11:14:31 PM |
Re: How could I make a window see-through it is once you have done it a few times ![]() |
| Posted by Mike53 at Jul 9, 2019, 11:31:06 PM |
Re: How could I make a window see-through If you still have difficulty with your velux HERE is a copy of the sh3d file i created my, fairly basic version, there are 2 groups, you can rotate 1 so it appears open or closed, before exporting it to create your window. Should you use it, bare in mind it will need the depth changing after positioning it in a wall. Mike |
Current timezone is GMT Sep 14, 2026, 8:09:35 AM |
