Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Importing 3DS files |
| Print at Jul 23, 2026, 8:10:18 AM | |
| Posted by lexvo at Dec 8, 2007, 4:57:00 PM |
Importing 3DS files I made an object in .3DS that I want to import in SweetHome 3D. How can I get the colors I set in the editor (Wings 3D) in SweetHome 3D? I downloaded an object from the internet which shows colors in both Wings and SweetHome. What am I missing? Thanks in advance. [Note: this thread was started on sourceforge.net forums] |
| Posted by Lucas at Dec 22, 2008, 12:51:00 PM |
Re: Importing 3DS files i have the same problem plus the following: - sometimes i try to download some 3ds from the internet and i get a non-3d picture which obviously i can't use - if i try to create my own obj i get a white object without the chance to assign a texture or a color - if i download a 3ds from the internet i get a white item and i cannot assign a texture or color |
| Posted by Lucas at Dec 22, 2008, 12:57:00 PM |
Re: Importing 3DS files PS - I also read this: http://sweethome3d.eu/faq.html#errorIn3DRenderingSystem Let me know if you can fix it |
| Posted by Lucas at Dec 27, 2008, 4:00:00 PM |
Re: Importing 3DS files i noticed that in the last step of the importation if i change the measures it works so i solved the problem, then! |
| Posted by Puybaret at Jan 2, 2009, 6:14:00 PM |
Re: Importing 3DS files Could you send me the file or the link to the file that caused this problem ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Johan_Martijn_Flaton at Feb 9, 2009, 5:42:00 PM |
Re: Importing 3DS files I have the same question about importing 3D files with textures. I've a 3D painting with frame and picture, but when I'm importing it with the Import furniture command I'm only getting the frame and no picture at all. I'm using Poser 7. Apart from that the programme is an absolute joy! |
| Posted by Puybaret at Feb 9, 2009, 5:47:00 PM |
Re: Importing 3DS files Create a zip file that contains the 3DS file and its textures. Then import the zip file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 23, 2026, 8:10:18 AM |
