Print at Oct 6, 2026, 12:07:21 PM
Posted by YGYL at Jun 12, 2019, 11:04:25 AM
rose   Twinmotion 2019 is free!! Recommendation Sweet Home 3D can directly export twinmotion file format
Now the OBJ exported by Sweet Home 3D can be imported into TW2019, but the direction is wrong and the glass material should be reset.
It takes a little time to reset.
If it is directly compatible with twinmotion format,
If SweetHome3D is imported into twinmotion and can be rendered directly,
That's a great thing.
The VR function of Twinmotion 2019 is very powerful, and the video rendering is very fast. And it should support ray-tracing rendering in the future. And it's free software.
https://twinmotion.abvent.com/
Posted by RockE at Oct 29, 2019, 9:09:21 AM
Re: Twinmotion 2019 is free!! Recommendation Sweet Home 3D can directly export twinmotion file format
[/url]
So how does one get the exported object to display in Twinmotion correctly? Is it a Sweet Home 3D export issue or a Twinmotion input issue?
I exported my home and it is standing on it's side, using the different axis import options I can get it upside down or below the surface.
Posted by hansmex at Oct 29, 2019, 2:46:45 PM
Same here
Posted by Rolander at Sep 26, 2020, 5:15:45 PM
Select the whole import (project) on the ride side and use the move and turn function (the triangle that shows up) of Twinmotion to put it in the correct direction plane.
