Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Badly managed Java method on Mac OS X ? |
| Print at Sep 20, 2026, 3:33:09 PM | |
| Posted by enkonyito at Jun 11, 2019, 5:19:46 AM |
Badly managed Java method on Mac OS X ? In this thread, a window always stays on top of others on Mac OS X while the default behavior is the opposite. Since this problem does not seem to occur on other systems, I suspect a badly managed Java method on Mac OS X. What do you think? Use the default behavior of the standard photo panel is not suitable because it destabilizes the progress bar by opening another photo panel. Forcing the window to not always be on top, temporarily fixes the problem because after an action in Sweet Home 3D, the window always goes back on top. final JDialog dialog = optionPane.createDialog(SwingUtilities.getRootPane((Component) parentView), this.dialogTitle);The PhotoVideoRendering plug-in is compiled with the JDK 8u201. Enko ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Jul 29, 2019, 11:43:57 PM |
Re: Badly managed Java method on Mac OS X ? Your suggestion was right, Enko, it was a Java-issue. After installing the latest java update, the problem is now gone! Tested again and again, same result. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 20, 2026, 3:33:09 PM |
