Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Import set of models from .dae (Collada) file |
| Print at Sep 20, 2026, 2:15:31 AM | View all posts in this thread on one page |
| Posted by lensmike at May 17, 2019, 12:19:15 PM |
Import set of models from .dae (Collada) file Hi all, I found a kitchen library in the sketchup warehouse _ttps://3dwarehouse.sketchup.com/model/71fa3db5-4bef-4891-b9a6-adbc9ab36d93/Kitchen-Cabinet-Set but when I import it into SweetHome it gets imported as a single model of a huge size. Is there a way to import several models from a single .dae Collada file as separate models? |
| Posted by hansmex at May 17, 2019, 3:13:51 PM |
Re: Import set of models from .dae (Collada) file 1 - Install Sketchup 2 - Load file 3 - Delete all models, except one 4 - Export model 5 - Undo Delete 6 - Repeat steps 4-6 PROBLEM(s) This procedure can be done ONLY with the SKP version of the file. Last free (as in zero-dollars) version of Sketchup is v2015. Oldest model version is 2016, which cannot be used used to open a newer file. Therefore you will have to use a paid version of Sketchup to do this. (The free online version doesn't allow exporting models) ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 2:15:31 AM |
