Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: window cut outs |
| Print at Sep 20, 2026, 9:36:06 AM | |
| Posted by Mike53 at May 12, 2019, 1:19:35 PM |
window cut outs Is there a specific reason any shape i create for a window cuts a wall correctly when the wall is straight but reverts to a large square hole when positioned in an angled or arced wall. ![]() Mike |
| Posted by Mike53 at May 12, 2019, 1:20:38 PM |
Re: window cut outs Is there another workaround or plug-in to counteract this issue? |
| Posted by Mike53 at May 12, 2019, 2:51:27 PM |
Re: window cut outs Sussed out the angled wall, cannot figure the arced wall, think i will have to simplify the cut-out, even though it is a library item, then create a window to match it, which seems backwards. Mike |
| Posted by Mike53 at May 12, 2019, 2:52:41 PM |
Re: window cut outs Must be getting old, chatting to myself now. ![]() |
| Posted by FDpaffie at May 12, 2019, 9:44:35 PM |
Re: window cut outs in order to get a good cutout u have to experiment by rotating your object, set it to align with your wall, and edit it Manuel ,even 0.1 deg up or down can give u a good cutout Example ; 1 If your wall has a Angle of 120 deg, set the angle of the window to 338.5 or 158.4 2 If your wall has a Angle of -103 deg, set the angle of the window to 192.9 or 12.8 ![]() ---------------------------------------- To Draw or not to Draw ...... Thats nolonger a question .. We draw |
| Posted by Mike53 at May 12, 2019, 10:11:25 PM |
Re: window cut outs Thank you for the suggestion FDpaffle, appreciate your taking the time to reply, i was more concerned with the cut-out than the actual window, as i was fitting a vertical window into a sloping roof, here is an image to explain what i was trying to achieve. ![]() Thx again. Mike |
| Posted by Puybaret at May 13, 2019, 9:18:29 AM |
Re: window cut outs Sorry, round walls accept only rectangular cutouts. With the current version, the only workaround would be to simulate a round wall with small straight wall parts but it requires some patience! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by FDpaffie at May 13, 2019, 6:25:56 PM |
Re: window cut outs maybe this is a work around to create this roof and his dormers i used only boxes and Triangles from the library ![]() ---------------------------------------- To Draw or not to Draw ...... Thats nolonger a question .. We draw |
Current timezone is GMT Sep 20, 2026, 9:36:06 AM |
