Print at Sep 27, 2026, 2:23:08 PM
Posted by Luzi3D at Apr 28, 2019, 12:24:29 AM
"schräge" Box zeichnen?
Hallo,
gibt es die Möglichkeit, eine Kist so zu editieren, dass sie nicht rechtwinklig ist, sondern in der Draufsicht schräge Kanten hat? Ich hoffe, man versteht, was ich meine ;)
Danke und LG
Luzi
Posted by Mike53 at Apr 28, 2019, 1:38:46 AM
Re: "schräge" Box zeichnen?
I am not sure if you can edit a box, but you can certainly make the shape you describe with the shape generator tool, you will find it tools>generate 3d shape
Posted by Luzi3D at Apr 28, 2019, 1:16:32 PM
where do I find "tools"?
Thanks!!
Posted by Mike53 at Apr 28, 2019, 1:19:20 PM
drop down box top left of main screen file...edit...Furniture...etc
Posted by Luzi3D at Apr 28, 2019, 1:28:08 PM
Ahh found it, it's a plug in :)Thank you!!
Posted by Mike53 at Apr 28, 2019, 1:46:43 PM
If the shape you require has more points than the generator allows then an option would be to draw the profile of your shape with the "create room tool, this will need to be done on an elevated level, not 0 elevation, then export it, 3D view>export to obj format, then import it, furniture> import furniture, during the import process you can re-orientate the object.
