Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Texture Library Editor |
| Print at Oct 9, 2026, 6:14:31 AM | |
| Posted by techdoctor at Mar 26, 2019, 5:53:33 PM |
Texture Library Editor Several problems. Running Windows 10 Pro 64bit. Updated to latest version as of 25/03/2019 I can't run the editor just by double clicking it. I have to use the command line, and it runs fine. Re-installed java and still have the same problem. I have checked the java config file and Java is enabled. associated .jar files to run with the java.exe . Second problem Where are the textures located. It seems windows has a messy way of storing files, found some textures here AppData\Roaming\eTeks\Sweet Home 3D\textures but these are zip files. Also I was unable to locate this directory path using the editor first try. Opened file explorer and navigated to the textures path , then tried again in the editor and it worked. Third problem I have accidentally imported the same texture twice and want to delete one of them. Program idea. It would be nice to be able to display all available textures in a way similar to the objects in Sweethome 3d and be able to modify them within the program Many thanks and look forward to your replies. |
| Posted by techdoctor at Mar 29, 2019, 11:08:16 AM |
Re: Texture Library Editor So no takers on helping me with the problems then. |
| Posted by Mike53 at Mar 29, 2019, 1:28:12 PM |
Re: Texture Library Editor On your 3rd issue.. if you select an item, any will do, >modify>texture, all imported textured names are in italics, when you select them the delete option becomes active, this is not the case for stored textures. Never used the editor so i cannot help with other issues. Mike |
| Posted by techdoctor at Apr 2, 2019, 4:37:05 PM |
Re: Texture Library Editor Thanks Mike, can't believe I missed that. I can't be the only one who can't get .jar files working by double clicking them. I did a google and followed the advice there but still no joy. |
| Posted by Mike53 at Apr 2, 2019, 5:07:43 PM |
Re: Texture Library Editor I never could get it to open with double click rither, windows 7,it may have an association issue, java i believe, but not sure on that, then when i did open it i had no idea what to do with it as usual, so i got rid.Mike |
| Posted by techdoctor at Apr 2, 2019, 6:20:58 PM |
Re: Texture Library Editor Just created a bat file using note pad. in notepad write this java -jar FurnitureLibraryEditor-1.24.jar Now save it as a .bat file. Furniture editor and texture editor now work. How I hate Windows |
| Posted by Mike53 at Apr 3, 2019, 1:47:09 PM |
Re: Texture Library Editor I am sure people, not me personally, will find this helpful, 2 questions though, what would the string for the texture editor be and i assume you created the .bat file while it was on your desktop, is it still there or did you have to place it elsewhere? |
| Posted by techdoctor at Apr 15, 2019, 7:00:51 PM |
Re: Texture Library Editor The Bat file is in the same folder as the Texture Library Editor. Open notepad and write this java -jar TextureLibraryEditor-1.6.jar and save it as a .bat file |
Current timezone is GMT Oct 9, 2026, 6:14:31 AM |
