Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Can't run application |
| Print at Jul 22, 2026, 2:28:42 PM | |
| Posted by Jason_Mazzotta at Aug 12, 2007, 10:20:00 PM |
Can't run application Hi, I'm trying to run Sweet Home 3D on windows. I'm using NetBeans to build and run the application. I was able to compile the application. However, when I try to run it, I get: java.lang.NoClassDefFoundError: and Exception in thread "main" Can anyone tell me how I can trace the source of this error? Thanks, Jason Mazzotta [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Aug 13, 2007, 4:13:00 AM |
Re: Can't run application The easiest way to run Sweet Home 3D is with its online JNLP file available at http://sweethome3d.sourceforge.net/SweetHome3D.jnlp . If you want to run it from NetBeans you should run the class com.eteks.sweethome3d.SweetHome3D with the system property java.library.path equal to the lib/windows Sweet Home 3D sub directory (thanks to the Java option -Djava.library.path=path/to/lib/windows). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 22, 2026, 2:28:42 PM |
