Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Exception in thread "AWT-EventQueue-0" |
| Print at Sep 20, 2026, 9:49:02 AM | |
| Posted by Iun8teic at Mar 13, 2019, 2:22:56 AM |
Exception in thread "AWT-EventQueue-0"hey guys. i lost the 3d-view while editing my model. everything was fun but after adding a shelf the 3d-view got lost and now i only see a gray area and i have no idea how to step back to a working file. i use ubuntu 16.04.6 with SH3D v6.1.2 (Java Version 1.8.0_202 - 64bit - 0,1/3,6 GB) and some libraries (BlendSwap-CC-0.sh3f Contributions.sh3f eTeksScopia.sh3t LucaPresidente.sh3f Scopia.sh3f BlendSwap-CC-BY.sh3f Contributions.sh3t KatorLegaz.sh3f Reallusion.sh3f Trees.sh3f) this is the first time i got such a problem with SH3D! if i open my file (it has 14MB) i got the following output: Exception in thread "AWT-EventQueue-0" javax.media.j3d.BadTransformException: TransformGroup: non-affine transformto fix this problem i already tried the following (unfruitful) steps: - switching the view (CTRL+D ; CTRL+CAPS+D ; CTRL+D) - reboot and open again with v6.1.2 - increase memory (from -Xmx2g to -Xmx4g) - open the file with SH3D 5.7 - rename the ".eteks"-Folder in $HOME can someone help? |
| Posted by Puybaret at Mar 13, 2019, 10:24:05 AM |
Re: Exception in thread "AWT-EventQueue-0" I already saw that problem in Sweet Home 3D. This is generally due to some objects placed at unknown coordinates (with NaN values) that prevents from computing a correct point of view. What I would like to know is how such values could happen... Anyway, you should be able to fix it by yourself this way: - backup your SH3D file - edit the Home.xml file it contains with a text editor - in the Home.xml, remove the lines containing <observerCamera> or <camera> XML elements with some attributes equal to NaN - replace other NaN values by 0 - save the Home.xml file and reintegrate it in the SH3D file If it doesn't work, or if you feel this is too much for you, just send me your file. I'll fix it for you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Iun8teic at Mar 13, 2019, 5:57:22 PM |
Re: Exception in thread "AWT-EventQueue-0" THIS IS SOLVED! omg. THANK YOU!! yes, i lost the 3D-view while placing a shelf in a corner. but it snapped on a furniture nearby and the 3D-view was gone in exact this moment... here is what i done according your solution: After opening the fixed file i got the 3D-view back! thank you. thank you. thank you. |
| Posted by UbuntuBirdy at Mar 13, 2019, 7:06:32 PM |
Re: Exception in thread "AWT-EventQueue-0" Hey, and upgrade to Ubuntu 18.04. Many problems with SH3D are avoided. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Sep 20, 2026, 9:49:02 AM |
