Print at Sep 20, 2026, 6:23:58 PM
Posted by marius_roma at Jan 27, 2019, 9:48:35 PM
Opening a door
I apologize for the very basic question.
I created a door but I want to see it open, so that I can see thru it.
How can I do?
Regards
marius
Posted by FDpaffie at Jan 28, 2019, 1:43:37 PM
Re: Opening a door
perhaps this topic will help you in Features use and tips Door swing in plan
Posted by FDpaffie at Jan 28, 2019, 1:52:07 PM
Re: Opening a door
a simple solution is using a Door frame and set the door at a angle
Posted by maladroit at Apr 11, 2024, 10:04:09 AM
Re: Opening a door
[Moderated] My Google search for "sweet home 3d open door" turns up this thread, which has over 5000 views, so I assume people want to know how to open a door in Sweet Home 3D, like I did. This is not explained anywhere for new users.
The answer, for anyone wondering, is to double-click on the door, or right-click and select "Modify furniture". In the pop-up, click the "Modify openings" button. From there you can see a 3D model of the door which you can click and drag to swing the door open or closed. Click OK to close the popups once you are done.
Posted by Puybaret at Apr 11, 2024, 4:30:40 PM
Re: Opening a door
maladroit, the solution you propose will work only for the doors in the existing libraries.
For door models designed by yourself, it's more complicate.
Posted by A.D.STUDIO at Apr 12, 2024, 4:53:49 PM
Re: Opening a door
Don't apologise, I learnt something here :)
