Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: PhotoVideoRendering-1.6 installation in Linux |
| Print at Sep 13, 2026, 10:14:30 AM | |
| Posted by svedel77 at Jan 27, 2019, 12:46:15 PM |
PhotoVideoRendering-1.6 installation in Linux Hi, I'm fairly new to Linux. I'm running Linux Mint. After installing SH3D via Synaptic, I can't find the plugins folder, to copy plugins to. What am I missing? |
| Posted by UbuntuBirdy at Jan 27, 2019, 2:21:39 PM |
Re: PhotoVideoRendering-1.6 installation in Linux I guess that Mint handles the same as Ubuntu (especially if you have the Ubuntu-based version). Then in your home directory there is a hidden folder called ".eteks". In this folder you will find another called "sweethome3d" and in it you will find the directory you are looking for: "plugins". ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by svedel77 at Jan 27, 2019, 2:55:33 PM |
Re: PhotoVideoRendering-1.6 installation in Linux Hi, I've been looking, and turned on "Show hidden files". No .eteks folder though. |
| Posted by hansmex at Jan 27, 2019, 3:24:04 PM |
Re: PhotoVideoRendering-1.6 installation in Linux If the folder "plugins" doesn't exist, create it yourself in ./eteks/sweethome3d. Then copy your plugins into that folder. When you start SH3D it will load the plugins it finds in that folder. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by svedel77 at Jan 27, 2019, 4:34:54 PM |
Re: PhotoVideoRendering-1.6 installation in Linux Thank you, that did the trick. But now SH3D tells me, that the plugin is not compatible with this version of SH3D. I went on, and downloaded the 32 bit version instead. But... Running the terminal script, in the SH3D folder does nothing. A terminal window flashes, and closes. No more. What can I do? |
| Posted by svedel77 at Jan 27, 2019, 4:56:01 PM |
Re: PhotoVideoRendering-1.6 installation in Linux OK, i now have the right x64 bit version. I can click the "PhotoVideoRendering" meny item in SH3D, but nothing happens, when I click it. |
| Posted by hansmex at Jan 27, 2019, 5:29:24 PM |
Re: PhotoVideoRendering-1.6 installation in Linux From the top menu choose Photo-video rendering -> Simple photo rendering (v1.6) and a pop-up window appears that's slightly different from the "normal" rendering window. Check your settings, and GO. (Normally that should work) ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by svedel77 at Jan 27, 2019, 5:53:34 PM |
Re: PhotoVideoRendering-1.6 installation in Linux From the top menu choose Photo-video rendering -> Simple photo rendering (v1.6) and a pop-up window appears that's slightly different from the "normal" rendering window. Check your settings, and GO. (Normally that should work) Oh yes, I understand. But when I click the "photo video rendering" menu-item, the window doesn't pop up. Nothing happens. |
| Posted by svedel77 at Jan 31, 2019, 2:23:58 PM |
Re: PhotoVideoRendering-1.6 installation in Linux Now I have made an Ubuntu USB stick, instead of Linux Mint. Exact same thing. Clicking the Video rendering menu-item, then nothing happens, at all. |
| Posted by Puybaret at Jan 31, 2019, 2:41:49 PM |
Re: PhotoVideoRendering-1.6 installation in Linux Run Sweet Home 3D from a Terminal window. If the plug-in is incompatible some way, an error should appear in the Terminal window when you select one of its menu items. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by svedel77 at Feb 2, 2019, 8:10:44 AM |
Re: PhotoVideoRendering-1.6 installation in Linux Run Sweet Home 3D from a Terminal window. If the plug-in is incompatible some way, an error should appear in the Terminal window when you select one of its menu items. OK, I'll try it. |
Current timezone is GMT Sep 13, 2026, 10:14:30 AM |
