Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Textures disappears |
| Print at Sep 20, 2026, 5:02:26 AM | |
| Posted by thoron at Jan 26, 2019, 6:00:33 PM |
Textures disappears Not sure whether here the right place to post a problem I have with the textures of walls. One room in the project loses the wall textures from time to time w/o having touched this room in any way. The texture disappears in the 3D-view (see picture), but clicking on the wall shows that the texture is still there according to the dialog box (see picture). I found out after a certain time, that just closing SW3D and opening the file again makes the texture visible again. Any idea what could be the root cause? ![]() ![]() |
| Posted by Puybaret at Jan 26, 2019, 6:20:45 PM |
Re: Textures disappears Wouldn't have you draw two walls at the same place? Just right click on the wall, and check what appears in the Select object menu. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by thoron at Jan 26, 2019, 8:16:09 PM |
Re: Textures disappears Thanks for this hint. I checked it the way you described, but the walls of the room are just once. No double walls. |
| Posted by thoron at Feb 4, 2019, 8:31:38 AM |
Re: Textures disappears any further ideas for this issue? |
| Posted by hansmex at Feb 4, 2019, 9:44:21 AM |
Re: Textures disappears If you want, send me your file and I'll have a look. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by thoron at Feb 5, 2019, 5:19:09 PM |
Re: Textures disappears Hello Hansmex, many thanks for your friendly offer. The point is that my model actually has 42 MB, which appears too big to send by mail. I will have a look, whether an earlier (and smaller version) has as well that failure. Then I will come back to you. |
| Posted by mukat at Mar 19, 2019, 11:42:08 PM |
Re: Textures disappears Hello thoron, I can't answer your question about a root cause, but I also get this from time to time. It appears to be sporadic and related to the 3D view. I did once render an image from a model while some of the walls were missing textures, and the textures did show up in the render. I'm on Windows 8.1 (64 bit), using Intel HD Graphics 4000. |
| Posted by hansmex at Mar 20, 2019, 1:41:22 AM |
Re: Textures disappears Do you have more than one version of Enkonyito's plugin installed or present in the living folder, even if the older version has been renamed? H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by mukat at Mar 20, 2019, 5:21:59 PM |
Re: Textures disappears Hello hansmex, I don't know if you're replying to me or thoron, but I have two of Enkonyito's plugins in SH3D's plugins folder (under AppData). No problems for me so far. |
Current timezone is GMT Sep 20, 2026, 5:02:26 AM |
