Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Split walls aaarrrghhhh. |
| Print at Aug 25, 2026, 7:52:37 AM | |
| Posted by Mike53 at Dec 27, 2018, 9:05:17 PM |
Split walls aaarrrghhhh. Hi. Having spent several hours moving a wall texture (tiles) on both x and y axis with several split sections , i was very pleased with the addition to allow this and the result, however, when i found it necessary to split the wall for the adjoining room i noticed that my tiling was ruined. Would it be possible in future to designate which side of the wall to split, or should i use 2 parallel walls. |
| Posted by Mike53 at Dec 28, 2018, 10:59:58 AM |
Re: Split walls aaarrrghhhh. I apologise for posting this here, it should probably have gone into "developers". Mike |
| Posted by Puybaret at Jan 8, 2019, 3:07:00 PM |
Re: Split walls aaarrrghhhh. Did you try to adjust the X offset of the texture on the side of the wall you didn't want to change? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Mike53 at Jan 10, 2019, 11:09:21 PM |
Re: Split walls aaarrrghhhh. Sorry Emmanuel, missed your reply. I did try but it got too frustrating changing each side to find a match, instead i used twin (cavity) walls, this brought action brought its own issues, windows, doors etc, they seemed easier to work with. Thanks Mike |
Current timezone is GMT Aug 25, 2026, 7:52:37 AM |
