Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: new version |
| Print at Sep 29, 2026, 8:49:13 AM | View all posts in this thread on one page |
| Posted by adrianoisoardi at Dec 10, 2018, 9:19:07 AM |
new version I installed 5.7 version, but it doesn't start. Then I installed the last version 6.0, with the same result: it doesn't start. Someone can tell me what kind of problem could I have? (I have Java last version). Thanks. Ho installato la versione 5.7 ma non parte. Lo stesso succede con la versione 6.0. Qualcuno sa dirmi che tipo di problema potrei avere? (La versione Java รจ l'ultima disponibile). Grazie. |
| Posted by hansmex at Dec 11, 2018, 8:51:03 AM |
Re: new version Which operating system do you use? ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by adrianoisoardi at Dec 11, 2018, 8:56:47 AM |
Re: new version windows 7 |
| Posted by Puybaret at Dec 11, 2018, 11:33:04 AM |
Re: new version What do you mean by "it doesn't start"? You get absolutely no message, just a double click on Sweet Home 3D icon then nothing... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by adrianoisoardi at Dec 11, 2018, 11:59:25 AM |
Re: new version After double click on the SH3D icon, the first image: Sweet Home 3D eTeks Copyrights 2007-2017 eTeks Distribuited under GNU... appears and remains fixed on desktop but the program doesn't start and I can't remove it. I tried to download and install new version many many times but nothing. |
| Posted by Brynmawr at Dec 31, 2018, 6:36:38 PM |
Re: new version I think I can add to this problem :- I have downloaded SweetHome3D-6.0 under Ubuntu 18.04, extracted the tar into my home directory and opened a terminal. I then ran :- CD SweetHome3D-6.0 ./SweetHome3D This resulted in the SweetHome introductory window opening but then the following error messages in the terminal :- Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2071) at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1924) at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875) at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1843) at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80) at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230) at java.security.AccessController.doPrivileged(Native Method) at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216) at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297) at com.jogamp.opengl.GLProfile.get(GLProfile.java:1021) at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050) at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803) at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267) at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:348 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) Does this help and, if so, what can we do to correct the problem? |
| Posted by DerekvG at Jan 3, 2019, 5:36:34 PM |
Re: new version @brynmawr I have the same problem : SweetHome3D-6.0 under Ubuntu 18.04, extracted the tar into my .eteks/ directory and opened a terminal. I then ran :- cd .eteks/SweetHome3D-6.0 ./SweetHome3D NO errromessages appeared on dekstop the startup image is shown : Sweet Home 3D eTeks Copyrights 2007-2017 eTeks Distribuited under GNU... remains fixed on desktop but the program doesn't start |
| Posted by Puybaret at Jan 3, 2019, 6:52:15 PM |
Re: new version Please try to run the alternate script SweetHome3D-Java3D-1_5_2 found in the same folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Brynmawr at Jan 3, 2019, 7:46:32 PM |
Re: new version Please try to run the alternate script SweetHome3D-Java3D-1_5_2 found in the same folder. It gives the error message :- Java 3D: implicit antialiasing enabled Gtk-Message: 18:43:47.185: Failed to load module "canberra-gtk-module" But SweetHome is up and, apparently, running. Thank you, I'll start climbing the learning curve :-) |
| Posted by Puybaret at Jan 8, 2019, 3:01:57 PM |
Re: new version Great! The curve shouldn't be too steep ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 8:49:13 AM |
