Print at Sep 13, 2026, 11:54:23 PM
Posted by svedel77 at Dec 9, 2018, 7:49:43 AM
PhotoVideoRendering-1.6 crashes
When rendering a movie using PhotoVideoRendering-1.6 plugin, SH3D crashes after a few minutes. No errorcode or description. It just crashes. This is if I render in 1920x1080 pixels. Rendering the same job in lower resolution, SH3d does not crash.
Rendering a movie with the built-in renderer, it's not a problem.
SH3D version 6.0
PhotoVideoRendering version 1.6
Posted by enkonyito at Dec 11, 2018, 12:18:42 AM
Re: PhotoVideoRendering-1.6 crashes
Hi svedel77,
What do you mean by SH3D crashes? It closes? Freezes?
For what quality?
You can send me your file in private message if it's possible.
Enko
EnkoNyito
Posted by svedel77 at Dec 17, 2018, 11:38:25 AM
Hi Enko,
SH3D closes down, without warning or errorcode. Sometimes after 20 seconds rendering. Other times after several minutes.
I've uploaded my project right here : www.pionersoft.dk/jpg/Danavejs.sh3d
- Søren
Posted by hansmex at Dec 17, 2018, 1:35:25 PM
Soren,
Your image rendered without problems in 52 minutes. Memory usage was around 5-6 GB.
Check Help -> About to see how much memory is available for SH3D on your computer.
If necessary use the XMX-trick to increase memory.
Posted by svedel77 at Dec 17, 2018, 1:48:54 PM
OK, I'll look into it.
