Print at Sep 14, 2026, 9:53:50 AM View all posts in this thread on one page
Posted by bigjim33 at Dec 5, 2018, 6:08:41 PM
raising existing walls and ceiling
hello to all,
I started to draw a project without noticing that the wall height is set to 250cm instead of 290cm. May I raise all the existing walls and the ceiling to 290cm at once?
thanks,
Marco
Posted by VeroniQ at Dec 5, 2018, 8:26:05 PM
Re: raising existing walls and ceiling
Hello Bigjim.
Select your whole design in Plan with Ctrl A (or cmd A on masOS), then Plan > Modify wall and change the height. Only your walls will be changed. If you have only one level, the ceiling will adjust itself at 290 cm. If you need a level, you can read this blog article .
Posted by bigjim33 at Dec 11, 2018, 3:35:08 PM
thank you!
Posted by HananeBelyekdoumi at Dec 20, 2020, 8:23:08 PM
Is there a way to raise the walls in the online version of sweet home 3d? I was also wondering if there is a way to put a roof in the online version.
Posted by Puybaret at Dec 20, 2020, 11:04:07 PM
The Online version isn’t finished, and you’ll have to be patient before these features become available. If you need them, I would suggest to export your online design and modify it with the installer version.
