Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Import set of objects |
| Print at Sep 6, 2026, 4:23:28 AM | View all posts in this thread on one page |
| Posted by basvanh at Nov 24, 2018, 9:55:27 PM |
Import set of objectsHello, I would like to design a kitchen. I have found a set of kitchen cabinets which I would like to import into SH3D. I have downloaded it as an Collada File. I have imported the object as a single furnature. When I drag it onto my drawing, its a single object with all the caibinets. How can I import it and use al its cabinets/object seperately? The 3d set: https://3dwarehouse.sketchup.com/model/71fa3d...36d93/Kitchen-Cabinet-Set Thank you in advance, regards, Bas |
| Posted by hansmex at Nov 25, 2018, 12:51:41 AM |
Re: Import set of objects 1 - install SketchUp 2 - open your kitchen file 3 - delete all models except one 4 - export your model 5 - use Undo to restore all models 6 - repeat steps 3 to 5 until all models are exported Good luck!! H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Nov 25, 2018, 12:53:12 AM |
Re: Import set of objects As I’m not sure that the free version of SketchUp will allow you to export a file at Collada format, I would import it in Blender which will let you export to OBJ or Collada formats only the selected object. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 25, 2018, 1:29:09 AM |
Re: Import set of objects Install SketchUp 2015, last free version with export. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by basvanh at Nov 25, 2018, 4:58:49 PM |
Re: Import set of objects Got it working with SketchUp 2015, thanks ! |
Current timezone is GMT Sep 6, 2026, 4:23:28 AM |
