Print at Sep 20, 2026, 12:53:07 AM View all posts in this thread on one page
Posted by delaing at Nov 24, 2018, 7:40:40 PM
Need ability to input offset value in Foot/Inch/Fraction data fields
I just found out with the help of @okh that it is not possible to input a value, say +5' (five feet), as an offset value in the X-Y coordinate fields of the Modify Wall dialog if application preference is set to Foot/Inch/Fraction.
You can see the discussion here:
Draw (offset) Wall from Existing Wall?
Why would this be available for Metric and Inch/Decimal but non-functional in Foot/Inch/Fraction?
Thanks in advance,
Delain
Posted by Puybaret at Nov 25, 2018, 12:59:55 AM
Re: Need ability to input offset value in Foot/Inch/Fraction data fields
Because the metric system doesn’t need ' and " characters. If you use Inch/Decimals unit, you’ll be able to enter mathematical expressions too.
Posted by okh at Nov 25, 2018, 3:06:15 PM
If so, I would use (7*12)+11 to insert 7 feet 11 inches (with inch/decimala in preferences). However, that does not give me 95 as expected. Am I missing something...? ok
Posted by Mike53 at Nov 25, 2018, 8:27:35 PM
hi OK
If you input this formula (7*12)+11 into the "modify wall" dialogue box, then the wall moves, for some reason, 18'8 3/8", 224.37". Whereas if you enter the formula into the "move selected item" dialogue box it does then move 95"
Posted by Mike53 at Nov 25, 2018, 8:40:06 PM
Have to ask, would it not be simpler, and it seems to work, using x as its original position inputting x+95
Posted by Puybaret at Nov 25, 2018, 9:07:37 PM
224.36 = (7 x 12 x 2.54) + 11
and 2.54 cm = 1 inch
There must be a conversion bug in the parsing algorithm and this happens as soon as the unit is not the centimeter! sad
Posted by okh at Nov 25, 2018, 9:53:13 PM
..would it not be simpler, and it seems to work, using x as its original position inputting x+95...
Absolutely. My experiment was just to test the math-formula and show how to enter feet/inches with a cheat. Come to think of it, the easiest would be if everyone used metric smile
..conversion bug in the parsing algorithm and this happens as soon as the unit is not the centimeter...
Oh well, I guess the math function may have to wait one release in the non-metric world. ok
Posted by Puybaret at Jan 24, 2019, 4:21:07 PM
The bug was fixed in version 6.1. Thanks for your patience.
