Print at Sep 15, 2026, 4:46:39 AM
Posted by gcalavaro at Nov 18, 2018, 12:53:58 PM
customize function keys in windows to make keyboard shortcuts
I have been looking to set up function keys in Windows to speed up some commands I use more frequently.
For example Modify Walls has CTRL-SHIFT-E Keyboard shortcut, but I would prefer to put on F2, while I would like to put on F3 modify rooms and on F4 modify furniture.
Is there a way to make such setting?
Thank you very much for your attention
and keep up with this great work. This tool is really outstanding.
Ciao
Giuseppe
Posted by klaus0 at Jan 27, 2025, 1:02:46 PM
Re: customize function keys in windows to make keyboard shortcuts
If someone else comes across this: I solved it by writing a small bash script.
Requirements: Git for Windows, to be executed by "Git Bash". With default install location of Sweet Home 3D, has to be run in a shell that has been opened with admin permissions.
Modification: Adjust the variables at the beginning of the file. Should be self-explanatory.
The script:
#!/usr/bin/bash
# -*- coding: utf-8-unix -*-
# shellcheck enable=check-unassigned-uppercase
# shellcheck disable=SC2064
set -e -u
INSTALL_DIR="C:/Program Files (x86)/Sweet Home 3D"
JAR_FILE="${INSTALL_DIR}/lib/SweetHome3D.jar"
PACKAGE_FILE="com/eteks/sweethome3d/swing/package.properties"
KEY_OVERRIDES=(
E HomePane.MODIFY_ROOM
E HomePane.MODIFY_FURNITURE
E HomePane.MODIFY_WALL
E HomePane.MODIFY_DIMENSION_LINE
E HomePane.MODIFY
"control J" HomePane.JOIN_WALLS
ESCAPE HomePane.SELECT
L HomePane.CREATE_DIMENSIONS
J HomePane.CREATE_POLYLINES
T HomePane.CREATE_LABELS
W HomePane.CREATE_WALLS
R HomePane.CREATE_ROOMS
# back up the original file as a starting point
if ! [[ -e "${JAR_FILE}.bak" ]]; then
cp "${JAR_FILE}" "${JAR_FILE}.bak"
fi
# set up a temporary directory
TMPDIR=$(mktemp -d)
trap "rm -rf '$TMPDIR'" exit
cd "$TMPDIR"
# extract the settings files
unzip "${JAR_FILE}.bak" "${PACKAGE_FILE}"
# list current hotkeys
echo
echo CURRENT HOTKEYS
printf "%15s %8s %-20s %s\n" PANE KEYS MODIFIERS ACTION
perl -ne '
if(/^(?<pane>.+?)\.(?<action>.+)\.AcceleratorKey=(?<modifiers>(\w+ )*)(?<key>\w+)$/) {
printf "%15s %8s %-20s %s\n", $+{pane}, $+{key}, $+{modifiers}, $+{action};
' "${PACKAGE_FILE}" | sort
# modify the file
echo
echo MODIFYING HOTKEYS...
i=0
cp "${PACKAGE_FILE}" "${PACKAGE_FILE}.old"
while [[ $i -lt ${#KEY_OVERRIDES[@]} ]]; do
key=${KEY_OVERRIDES[$((i++))]}
action=${KEY_OVERRIDES[$((i++))]}
perl -pe "s{^$action.AcceleratorKey=.*}{$action.AcceleratorKey=$key}" -i "${PACKAGE_FILE}"
done
diff -U0 "${PACKAGE_FILE}.old" "${PACKAGE_FILE}" || true
# updating jar file
echo
echo UPDATING JAR FILE...
zip "${JAR_FILE}" "${PACKAGE_FILE}"
echo
echo DONE...
