Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two importing questions |
| Print at Sep 20, 2026, 1:47:28 AM | View all posts in this thread on one page |
| Posted by grrrlgeek at Nov 18, 2018, 2:57:50 AM |
Two importing questions Two questions. I've made several extra categories in the furniture list. I tried using the furniture library editor, to put a few things in the categories I made, then saved as a new library with a different name. Not one of them went in the categories I had created that I chose in the editor. The categories were already in the list because I had imported several objects into them. Is the furniture library not able to change the category from the one it was already in before I edited it? Was really hoping it would work. Second: when I import obj files, sometimes it brings the mtl file, sometimes it doesn't. Some obj files already have everything in them already, but most don'I. I tried to put the mtl and obj, and any separate jpg, png, etc. in a zip all together. Sometimes that works, most times not. It does import the mesh, skin, and shading regardless. I don't know enough about 3d editing to add the textures and colors onto them. I tried a few free programs, but the seem too complex just to do this. Is anything I've written make any sense? Can anybody help with these? |
| Posted by grrrlgeek at Nov 24, 2018, 1:54:56 AM |
Re: Two importing questions No takers? it's been read over 150 times. Anyone have any inkling? |
| Posted by Puybaret at Nov 24, 2018, 2:41:33 PM |
Re: Two importing questions The objects in the catalog are stored by categories and only the category name is used to make the difference from one to the other. Maybe you added some extra space in the name. About importing OBJ file, please provide some concrete files (or links to them) with which you had some issues. The MTL file is not mandatory and default colors are cited in this document. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 24, 2018, 2:57:33 PM |
Re: Two importing questions I tried to put the mtl and obj, and any separate jpg, png, etc. in a zip all together. Sometimes that works, most times not. Please note that the MTL file is referenced from the OBJ file with an address. If, when combining OBJ and MTL in a ZIP file, the (relative) address changes, the OBJ file cannot find the MTL file, and will ignore the date contained in it, resulting in an object without colours and/or textures. When this happens, check your OBJ file to know the exact address, then either change the address in the OBJ file, or make sure that the MTL file is where the OBJ says it should be. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by grrrlgeek at Nov 25, 2018, 6:57:35 AM |
Re: Two importing questions The categories are almost all one word, like Animals or Plants. They work fine for importing one by one.The furniture library editor allow me to change the categories of the items in it, so I thought I could put them in those categories, but it ignores any of those changes when imported. I'll have to experiment and see if any of the obj that didn't grab the mtl were in a different configuration. Thanks. |
Current timezone is GMT Sep 20, 2026, 1:47:28 AM |
