Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I select a wall and delete it? |
| Print at Sep 25, 2026, 4:07:31 AM | View all posts in this thread on one page |
| Posted by Jayroo at Nov 16, 2018, 10:51:07 AM |
How do I select a wall and delete it? This program is frustrating, how can I select a wall and simply delete it then start again? I can't select it, it keeps adding on new wall when i click on it, right click does nothing either, I am using the PAID version from amazon |
| Posted by VeroniQ at Nov 16, 2018, 12:59:16 PM |
Re: How do I select a wall and delete it? You have to come back to "Select objects in plan" tool (the small arrow) or with Ctrl L. May be the reading of the user's guide will help you, especially this part? |
| Posted by Matam at Jan 7, 2019, 2:08:10 AM |
Re: How do I select a wall and delete it? This didn't work. Is someone able to explain it in another way that is easier to understand please? I am using a MacBook Air. Thank you, Matam |
| Posted by okh at Jan 7, 2019, 11:42:00 AM |
Re: How do I select a wall and delete it? Did you by accident lock the plan - clicking the little padlock in the top left corner of the 2D pane? ok |
| Posted by Matam at Jan 7, 2019, 12:04:34 PM |
Re: How do I select a wall and delete it? Hi, No the padlock is unlocked, thanks anyway. But I'm pleased to find that It now works . I can't identify what I did was different, unfortunately. For the benefit of the original poster and maybe others to follow, because it is tricky, I'll outline what I did. Go to Plan and select 'Select' rather than 'Create walls'. (On Apple MacBook Air) Next Hold down Command key while selecting with the cursor the wall you want to delete. Next from Edit select Delete. That bit of wall should disappear. If you made the wall by a couple of attempts you'll probably have to delete it by a couple of attempts. Cheers, Matam |
Current timezone is GMT Sep 25, 2026, 4:07:31 AM |
