Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3D-6.0-portable How to start from USB-stick |
| Print at Sep 25, 2026, 12:29:35 PM | View all posts in this thread on one page |
| Posted by otadmin at Nov 6, 2018, 8:32:33 AM |
SweetHome3D-6.0-portable How to start from USB-stick I am on linux-mint 19 and am using sweethome 3d since a while. Just downloaded SweetHome3D-6.0-portable and unpacked in on a USB-stick to take my projects to other computers. Question is how to start the program from the stick? If I double-click SweetHome3D-linux-x64 a text editor opens showing the code but does not run sh3d. |
| Posted by Puybaret at Nov 6, 2018, 10:05:41 AM |
Re: SweetHome3D-6.0-portable How to start from USB-stick Don't open SweetHome3D-linux-x64 with a text editor but run it as a script using this tip or in a Terminal window. Depending on how you copied files on your USB stick, you may also have to reset execution rights on SweetHome3D-linux-x64 and jre/linux/x64/jre8/bin/java files. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by otadmin at Nov 7, 2018, 6:01:07 AM |
Re: SweetHome3D-6.0-portable How to start from USB-stick Thanks, clear to understand. Learned about permissions! Now I get Error: Could not find or load main class com.eteks.sweethome3d.SweetHome3D . On the portable version the Furniture is in data. |
| Posted by Puybaret at Nov 7, 2018, 10:28:51 AM |
Re: SweetHome3D-6.0-portable How to start from USB-stick This could mean that you moved some files in lib subfolder. As explained at the end of the README.TXT file, you shouldn't move files found in the uncompressed folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by otadmin at Dec 14, 2018, 6:01:15 AM |
Re: SweetHome3D-6.0-portable How to start from USB-stick Just started up again. Nothing works! Whatever advice I implement the file opens in the text editor. I formatted the USB-stick to fat32 to be able to run it on different OS. But under linux I am unable to change any permissions. Noticed that the file name is SweetHome3D-linux-x64 with no ending. Should there not be a .js at the end? |
| Posted by otadmin at Dec 14, 2018, 6:19:42 AM |
Re: SweetHome3D-6.0-portable How to start from USB-stick Just to mention, it works fine when the stick is formatted to ext4. But then windows will not work with it. |
Current timezone is GMT Sep 25, 2026, 12:29:35 PM |
