Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: staircase generator |
| Print at Oct 5, 2026, 9:44:36 PM |
| Posted by adibuyono at Nov 3, 2018, 3:10:24 PM |
staircase generator First of all, thank you very much to provide such useful software for open source community. I always having trouble with the staircase provided in furniture, and I have zero knowledge about 3D modelling. I wish there is an easy way to create staircase met every user need. I think staircase generator would be a great idea for all of us. Staircase generator I mean is like : 1. first, we need to choose which kind of staircase we are going to regenerate. i.e : L shape staircase, U shape staircase, direct staircase. 2. Then, we need to enter how many steps for each part of stair case. For example : I choose L shape staircase, the lower part of the staircase is 4 steps, and the higher part of the staircase is 11 steps. 3. Last, we need to input how is the height and wide of each steps. and voila, the software generate a staircase for us. Anyway, this is just my two cents. If i am asking too much, I am really sorry. And again, sorry for my bad English. Hope everyone understand what I am trying to describe. |
| Posted by harbinger at Nov 5, 2018, 10:08:17 PM |
Re: staircase generator +10 on this! My staircases are never cookie-cutter, and they almost always require a special model, so of course i would support this. Altho it would be very complicated, this kind of customization would help take SH3D out of the "tinkering" genre of software to something more serious. This probably would be best suited as a plugin, but hopefully such a feature would allow for curved steps, customized bannisters/railing and its placement, and multiple texturization. I disagree on HOW MANY steps would need to be input, but rather the rise of each step, and the altitude that needs to be covered. Perhaps a separate option would allow you to put in a "break" for turning the angle of the staircase. |
| Posted by dorin at Nov 21, 2018, 10:54:29 AM |
Re: staircase generator I think this one and others could be a subject in developers part. In my imagination I see an entry in Menu like "Tools" or "Generators" with few entries: -shape generator -stairs or staircase generator -roof generator -furniture builder -terrain generator All of this could be made as individual plugins. First step was made by shape generator. For stairs generator could be used as start point for plugin developers the code (free) from AOI named Array... in combination with shape generator. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Puybaret at Aug 13, 2023, 1:02:12 PM |
Re: staircase generator Try the Staircase generator plug-in available here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by arpy at Mar 17, 2024, 5:42:27 AM |
Re: staircase generator I'd like to generate a U shaped staircase with landing but one where I can specify the number of steps on each side. For example, I want 15 total steps, 12 on one side, then the landing, then 3 more down from the landing. Is there anyway to do this? |
| Posted by Xlance at Apr 8, 2024, 3:34:52 PM |
Re: staircase generator Hello All I've created an updated interface with more proposed functions for the plugin, but no actual programming as I'm not proficient in java. If anyone is interested to actually implement the functions, you'll find an eclipse project here along with explanations: https://sourceforge.net/p/sweethome3d/feature-requests/1169/ Thank You ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
| Posted by Xlance at Sep 6, 2025, 2:19:02 PM |
Re: staircase generator The next upgrade ! work in progress :-) https://freeimage.host/i/Knhqodb Width of the staircase Total height of staircase Height of each step Depth of each step Height of stringers Thickness of stringers Height of handrail from tread Width/thickness of handrail Width of a baluster Height of baluster Distance between balusters Radius of spiral staircase Total rotation angle (spiral) Horizontal placement offset Vertical placement offset Depth placement offset Select staircase shape Open file chooser to load custom obj baluster Open file chooser to load custom txt handrail profile ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
| Posted by dorin at Sep 9, 2025, 12:00:23 PM |
Re: staircase generator Looks very promising! One remark: you have to rotate the left handrail profile to make it symmetrical with the right. I like also the option to choose the turn between round and corner. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Xlance at Sep 12, 2025, 9:02:19 PM |
Re: staircase generator One remark: you have to rotate the left handrail profile to make it symmetrical with the right. Could be done I guess :-) I like also the option to choose the turn between round and corner. Very tricky ! I could supply the source if you can implement it ;-) Four Turn Stair Preview: https://freeimage.host/i/KToegK7---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
| Posted by Xlance at Sep 15, 2025, 7:27:34 AM |
Re: staircase generator . Palace Staircase: https://freeimage.host/i/KutmQAx . [full parametric modelling by the upgraded version of Staircase generator plugin and rendered on level 3]: . ---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins |
Current timezone is GMT Oct 5, 2026, 9:44:36 PM |
