Print at Sep 27, 2026, 1:35:42 PM
Posted by enkonyito at Oct 30, 2018, 11:15:15 PM
How to find the vertices of a 3D shape?
I want to automatically find the vertices (coordinates and indices) of a 3D shape.
I am currently studying methods related to exportNode of PhotoRenderer.java or writeNode of OBJWriter.java.
Is it a good starting point even if it is not easy to know what to keep or not?
The goal is to be able to use this information for TriangleMeshLight light sources.
Enko
EnkoNyito
Posted by enkonyito at Nov 3, 2018, 10:26:08 PM
Re: How to find the vertices of a 3D shape?
For SH3D lights, the types of geometric constructions detected are:
- TriangleArray (like the opaque light panel)
- LineStripArray (like the unviewable light panel).
Using,
GeometryInfo geometryInfo = new GeometryInfo (geometryArray);
with the type LineStripArray, I have the error message:
java.lang.IllegalArgumentException: Unsupported geometry type
Sunflow only considers triangle-based meshes for TriangleMeshLight light sources.
light {
type meshlight
name meshLamp
emit { "sRGB nonlinear" 1.000 1.000 1.000 }
radiance 100.0
samples 16
points 4
0.6 0.1 6.0
0.3 1.0 6.0
1.0 1.0 5.5
1.0 0.3 5.5
triangles 2
0 1 2
0 2 3
EnkoNyito
Posted by Puybaret at Nov 4, 2018, 6:49:43 PM
Without knowing what you stored in geometryArray, it's impossible to understand what is wrong.
If you look for simple examples, you could look at this tutorial and at the source code of ShapeGenerator plugin.
Posted by enkonyito at Nov 5, 2018, 5:31:34 PM
I use your tutorial to complete my information on the Javadoc of Java3D.
In geometryArray, the data about the object of any shape that I want to find the vertices is stored.
} else if (node instanceof Shape3D) {
Shape3D shape = (Shape3D)node;
// Read object geometries
for (int i = 0, n = shape.numGeometries(); i < n; i++) {
readNodeGeometry(shape.getGeometry(i), parentTransformations, texCoordGeneration,
textureTransform, cullFace, backFaceNormalFlip);
private void readNodeGeometry(Geometry geometry,
Transform3D parentTransformations,
TexCoordGeneration texCoordGeneration,
Transform3D textureTransform,
int cullFace,
boolean backFaceNormalFlip) {
if (geometry instanceof GeometryArray) {
GeometryArray geometryArray = (GeometryArray)geometry;
The ideal would be to force to use TRIANGLE_ARRAY.
EnkoNyito
Posted by enkonyito at Nov 20, 2018, 8:13:22 PM
To have a reference of what I had to look for, I performed tests in Sunflow directly by editing the example_scene.geo.sc file.
I have found that vertices are only well taken into account if they are grouped into a single object defined in the .obj file.
# 3D model cube_v2.obj
mtllib cube_v2.mtl
g cube
usemtl default
v 0.0 0.0 0.0
v 100.0 0.0 0.0
v 100.0 0.0 100.0
v 0.0 0.0 100.0
v 0.0 100.0 0.0
v 100.0 100.0 0.0
v 0.0 100.0 100.0
v 100.0 100.0 100.0
f 1 2 3
f 1 3 4
f 2 1 5
f 2 5 6
f 1 4 7
f 1 7 5
f 3 2 6
f 3 6 8
f 4 3 8
f 4 8 7
f 7 8 6
f 7 6 5
Results in Sweet Home 3D.
By launching the rendering several times, sometimes the triangle mesh light is not well applied.
I think I should put my method searchVertices (light) elsewhere than in exportLightSource especially since there is redundancy with some methods already present in the PhotoRenderer file.
EnkoNyito
Posted by enkonyito at Nov 26, 2018, 12:15:56 AM
Using or modifying existing methods in the PhotoRenderer class optimizes the dynamic search for coordinates and vertices indices of a 3D shape. smile
The quality and duration of rendering depends on the composition and complexity (number of triangular faces) of the object transforming into light.
Neon digits (created by alaX)
SH3D models
EnkoNyito
Posted by ndorigatti at Nov 26, 2018, 9:35:14 AM
So, let me understand.. are you finding a way to speed up rendering or trying to find a render result different than before?
Posted by enkonyito at Nov 26, 2018, 6:50:47 PM
Unfortunately, I do not think it is possible to speed up the rendering with Sunflow.
On the other hand, I found a way for Sweet Home 3D to take into account the mesh light rendering .
EnkoNyito
Posted by ndorigatti at Nov 26, 2018, 8:15:11 PM
So that you can have the whole mesh to light up? Could be interesting for my Philips homroo light model, where the glass part would be a mesh light!
Posted by Puybaret at Nov 26, 2018, 9:23:14 PM
Maybe this could be bound to triangles orientation. Did you try to reverse the order of the vertices?
Posted by enkonyito at Nov 27, 2018, 3:53:02 AM
@ndorigatti
Yes it's the whole object that lights up like a 3D silhouette.
For your model, perhaps you could extract the glass part to turn it into light and then group it to the rest.
@Puybaret
By reversing the order of the vertices indices of each face, the emission of the light is oriented on the opposite side.
As there is no change of the scene (several geometric shapes) between each rendering (without closing the photo panel), I wonder if Sunflow would not keep some parameters in memory (after Java 3D export) which would have the consequence a random rendering. Especially with only one geometric shape present in the scene, the rendering is always correct.
triangle mesh light_geometric shape.sh3d
For those who want to test the mesh light rendering, first add these keys and their property values
lightSourceX#n=0
lightSourceY#n=0
lightSourceZ#n=0
lightSourceColor#n=#919189
description#n=TriangleMeshLight
to your object in the PluginFurnitureCatalog.properties file of your light library.
Then install the PVR-1.7betaTest plug-in (simple photo rendering only).
Attachment PVR-1.7betaTest.sh3p (336242 bytes) (Download count: 375581)
EnkoNyito
Posted by enkonyito at Jan 24, 2019, 10:15:43 PM
Have you been able to turn objects into a triangle mesh light library?
How are they rendered?
Do you find this feature useful as a future version of the photo plug-in?
EnkoNyito
Posted by enkonyito at Mar 7, 2019, 12:44:54 AM
As this beta version of the plug-in is not 100% functional and does not seem to interest anyone, I do not think it will be made public.
EnkoNyito
Posted by enkonyito at Mar 10, 2020, 3:43:43 AM
With the YafaRay rendering engine it is no longer necessary to search for the coordinates of the vertices of an object.
Just use meshlight type light with the object ID .
EnkoNyito
