Print at Sep 14, 2026, 11:40:16 AM
Posted by farasat at Oct 29, 2018, 8:56:11 AM
sad   how should i fix this?
hi every one
i have a problem using sweet home 3d
like what you can see in this image
when i click ok sweet home 3d closes
this problem is in 5.0 and newer versions
thanks in advanced
Posted by Puybaret at Oct 29, 2018, 9:17:33 AM
Re: how should i fix this?
Under what system did you try?
Posted by farasat at Oct 30, 2018, 2:32:11 PM
Posted by Puybaret at Oct 30, 2018, 2:50:39 PM
Run the installer again, and select the 32 bit option when the installer prompts you to choose the destination folder.
Posted by farasat at Nov 1, 2018, 9:11:21 AM
applause   Re: how should i fix this?
i did it and the error has fixed
I really appreciate your help
Posted by Raevlav at Dec 6, 2018, 3:56:03 PM
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons.
Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
i have fixed the issues by the same solution - reinstall SH from 64bit to 32bit ver.
