Print at Aug 19, 2026, 4:10:24 PM
Posted by stef.salmon at Oct 23, 2018, 12:26:16 PM
Re: Background Pixelation
Why am I getting areas of pixelation on my floor layout background?
https://www.dropbox.com/s/a9d8hsiib5lm578/KWS_1stFloor5.png?dl=0
Thanks.
Posted by stef.salmon at Oct 25, 2018, 11:20:07 AM
I'm guessing the pixelation is due to some sort of shadow being cast?
I've tried changing coordinates on the compass but nothing seems to get rid of the shadows.
Any help would be greatly appreciated.
Thanks.
Posted by stef.salmon at Oct 26, 2018, 10:18:48 AM
If the shadows have to be there then so be it, but why aren't they a solid colour instead of pixelated? This is so frustrating!
I can't really use these rendered images on a customers site when they look like this.
https://www.dropbox.com/s/uqlkqrkbtx7c7r9/KWS_1stFloor%20-%20Copy.png?dl=0
It would be so much easier if there was a way of just selecting no shadows instead of messing around with coordinates and time of day.
Posted by bdfd at Oct 26, 2018, 10:57:55 AM
confused   Re: Background Pixelation
Generally, it happens with renderings in quality 3.
Did you try in quality 4 ?
biggrin
Posted by alaX at Oct 26, 2018, 1:24:43 PM
Looks like the same issue (with solution):
http://www.sweethome3d.com/support/forum/viewthread_thread,8958
Posted by stef.salmon at Oct 26, 2018, 2:52:03 PM
I tried setting the elevation to 1cm and also 2000cm but it makes no difference. I think it's the shadows full stop that are causing the problem.
See link.
https://www.dropbox.com/s/08xlggkpvh0vuza/KWS_1stFloor%20-%20Copy3.png?dl=0
Is it not easier, to just have no shadows?
Thanks.
Posted by Ceciliabr at Oct 26, 2018, 4:38:09 PM
What is the light source creating your shadows?
Have you tried IBL-lighting – applying a white texture to the sky and render with enhance external brightness checked and the time of day set to midnight?
cec
Posted by stef.salmon at Oct 26, 2018, 4:48:57 PM
What is IBL lighting and where do you get it?
Posted by stef.salmon at Oct 26, 2018, 7:09:30 PM
I think it's more of a problem with the rendering tool. There's no reason why the pixelation should be there...it's not even part of the shadow.
Posted by VeroniQ at Oct 26, 2018, 8:38:38 PM
Stef.salmon, you should read this thread by EnkoNyito and many others by Ceciliabr who nicely gives to the forum many tips about lighting.
Posted by Ceciliabr at Oct 27, 2018, 2:12:18 AM
IBL ( Image Based Lighting) is using an image as a light source, instead of using the sun.
The exact terminology (IBL) is not used here, instead it's called: Enhance external brightness,
and can be selected as an option if you install ( or have installed) THIS plugin,
which also offers some other tools for enhancing the rendering process.
Settings:
The best way to use this for your project is to apply a totally white texture ( not colour!) to your sky and ground.
You could also experiment with panel lights to further enhance your renderings.
Posted by stef.salmon at Oct 29, 2018, 9:27:38 AM
Thanks for all your help so far.
I have installed the 'PhotoVideoRendering - 1.6' plugin but it says it isn't compatible with the version of Sweet Home 3D.
I'm running SH3D v5.7
Posted by VeroniQ at Oct 29, 2018, 10:13:51 AM
There are different versions of EnkoNyito plugin in his thread but you should better upload the new 6 version of Sweet Home 3D...
Posted by stef.salmon at Oct 29, 2018, 11:43:21 AM
I installed Sweet Home 3D v6.0.
I chose a white texture for the ground and sky as suggested. I used white roughcast.
I checked the 'Enhance external brightness' box and set the time to 00:00 midnight and Q4, which it needs to be. As you can see from the rendered image, it is even worse than before and it took 10 times as long to render...51 minutes 40 seconds to be precise. Why it took that long I have no idea, it's not exactly very detailed.
https://www.dropbox.com/s/nqb2osf0z49uray/KWS_1stFloor%20-%20TEST.png?dl=0
I'm not producing very detailed 3D building layouts.
Where do I go from here?
Would it be easier for me to send the file to one of you guys with the proper expertise, to see if you can get it to render without pixelation?
Thanks.
Posted by Puybaret at Oct 29, 2018, 12:43:13 PM
I would suggest to create a large white zone around you building, and cut / paste everything else on top of that.
Posted by stef.salmon at Oct 29, 2018, 12:54:17 PM
Do you mean create a large white image .png and use this as the background, then copy and paste everything on to that?
Posted by Ceciliabr at Oct 29, 2018, 1:23:39 PM
White is #FFFFFF.
THIS is a white texture
Here is how it should render
Posted by stef.salmon at Oct 29, 2018, 1:30:52 PM
I have used your .png as a texture for the ground & sky. It's saying the estimated rendering time is 56 minutes...that can't be right?
Posted by UbuntuBirdy at Oct 29, 2018, 1:49:51 PM
If you are not working on Summit this is absolutely a real time for rendering at Q4.
Pascal
Posted by stef.salmon at Oct 29, 2018, 1:54:32 PM
OK that's understandable.
I made the pixel size smaller so it rendered faster, but there is still pixelation. See link.
https://www.dropbox.com/s/tcrjthgfnx2xos2/KWS_1stFloor%20-%20TEST2.png?dl=0
What else could be causing it?
Posted by UbuntuBirdy at Oct 29, 2018, 2:18:54 PM
If you want I can look at your sh3d file.
Pascal
Posted by stef.salmon at Oct 29, 2018, 2:21:11 PM
I'd appreciate it if you could, thanks.
https://www.dropbox.com/s/988kbwbj6r5qra5/KWS_1stFloor%20-%20TEST.sh3d?dl=0
It's just a basic floor layout, nothing too special.
Posted by UbuntuBirdy at Oct 29, 2018, 2:43:58 PM
Short question between the tests: what are the tech.specs of your system?
Pascal
Posted by Ceciliabr at Oct 29, 2018, 2:46:07 PM
Posted by Ceciliabr at Oct 29, 2018, 2:49:21 PM
Ooops! I chose reply instead of Preview post.
Here is your file fixed.
KWS_1stFloor - TEST-CBR.sh3d
cec
Posted by UbuntuBirdy at Oct 29, 2018, 2:50:17 PM
WOW cec, the rendering power of your system is impressive!
Pascal
Posted by stef.salmon at Oct 29, 2018, 2:54:56 PM
NVIDIA Quadro M620
https://www.dropbox.com/s/nk75g9ptkgp9uqd/System.png?dl=0
Posted by stef.salmon at Oct 29, 2018, 2:58:14 PM
Cec...Thanks.
what was the problem?
Posted by Ceciliabr at Oct 29, 2018, 3:13:10 PM
An old Mac Pro from 2014
2.7 GHz 12 core
128 Gb memory
Dual AMD FirePro D700 graphics processors with 6GB of GDDR5 VRAM x2.
2048 stream processors
384-bit-wide memory bus
264GB/s memory bandwidth
3.5 teraflops performance
4TB SSD
12TB BSD
It's faster than my fathers new 7000€ Dell 18 core on both CPU and GPU rendering.
Posted by Ceciliabr at Oct 29, 2018, 3:15:50 PM
Your ground texture was a wrong image.
Posted by stef.salmon at Oct 29, 2018, 3:33:11 PM
Is it possible to get the image larger?
If I open the 3D view and zoom in and then render, I get the pixelation again and it doesn't seem any larger?
I'm probably doing it incorrectly!
https://www.dropbox.com/s/ol5nlzs1yn3978x/KWS...20-%20TEST-CBR_2.png?dl=0
Thanks.
Posted by UbuntuBirdy at Oct 29, 2018, 3:36:02 PM
It's faster than my Ryzen system (8 core / 16 threads but 3.6 - 4.0 GHz)
Eventually your 128GB memory (I have only 32GB) are the key for fast renderings...
Pascal
Posted by Ceciliabr at Oct 29, 2018, 5:36:11 PM
Just rendered 3440 x 1440. No pixelation.
It's impossible to say what you are doing wrong.
Posted by UbuntuBirdy at Oct 29, 2018, 5:41:56 PM
Cec, I can reproduce the pixelation on my system even with your fixed file.
If I delete all the floors, the problem has gone. If I recreate the floors, the problem reappears.
Pascal
Posted by UbuntuBirdy at Oct 29, 2018, 6:34:11 PM
Cec, this is your file, just opened and directly rendered:
...as you said, no problem.
But zoomed in only a little bit:
... the problem reappears.
The biggest floor is a little bit displaced, so I tested if this can be the problem. But neither push it to the right position, nor delete the floor and rebuild it helps.
If you create a second level and then increase the original level by 1mm, you can see strange "rays" on the floors in the 3d view:
I suspect this has something to do with the problem, but I still can not figure out what exactly caused it.
Pascal
Posted by Ceciliabr at Oct 29, 2018, 6:43:08 PM
Try THIS file, and see if it helps.
I'm just guessing now, since I'm not able to reproduce the problem.
Posted by Ceciliabr at Oct 29, 2018, 6:45:25 PM
Maybe deleting the background image will help?
C
Posted by UbuntuBirdy at Oct 29, 2018, 8:11:07 PM
No luck, as before, just opened the file, switched from q3 to q4 and rendered:
Deleting the bg-image does not change anything.
I do not know what else to try, so I have to give up for the moment...
Pascal
Posted by Puybaret at Oct 29, 2018, 9:35:26 PM
Simpler than that: create a rectangle room that surrounds all your design as in the attached file.
Attachment KWS_1stFloor - TEST.sh3d (845152 bytes) (Download count: 79381) (Surrounding room)
Posted by Puybaret at Oct 29, 2018, 9:49:03 PM
I'm pretty sure that these "noisy rays" come from how the ground is cut around your home with large triangles that goes from the house border to the far away border of the scene.
I noticed that kind of noisy effect in other situations with SunFlow at very high points of view, and it's a reason why I limited the eyes elevation to 100m.
Introducing a rectangle room will produce a much simpler cut out in the ground around that rectangle, with smaller triangles around the house which will remain in that rectangle.
Posted by VeroniQ at Oct 29, 2018, 10:59:24 PM
By the way, if it is not too indiscreet, Stef.salmon, what is this strange building? It looks a little bit like a prison, or a secret factory... Hope you will satisfy my curiosity (but don't feel obliged)...
Posted by stef.salmon at Oct 30, 2018, 9:38:53 AM
VeroniQ - The building is actually an office block in London. The floor plan is a bit strange...looks a bit like a boat.
http://www.onekingwilliamstreet.london/new/index.html
Emmanuel - Your idea of putting the rectangle around the floor layout works perfectly, so thank you for that.
And thanks to everyone else who helped.
wink
Posted by VeroniQ at Oct 30, 2018, 12:32:15 PM
Thank you. Yes, peculiar but beautiful building! Will you model it entirely? I will be curious to see the result... Good luck.
Posted by stef.salmon at Oct 30, 2018, 12:58:37 PM
I would like to model the whole floor but it's not really required for what we're using it for.
Our company installs Building Management Systems, which control the heating & cooling and manages the energy usage of a building. We use various manufacturers and software packages to do this.
I'm working on a project at the moment LSE 'London School of Economics'. I've put a link to one of the floors there so you can see what I mean.
https://www.dropbox.com/s/7me7c6ox2xf7fxd/LSE_3rdFloor.png?dl=0
Cheers.
