Print at Aug 22, 2026, 12:18:08 AM
Posted by stef.salmon at Oct 12, 2018, 9:52:53 AM
Re: Single Glass Door
Is there a single glass door in any of the libraries?
I can't seem to find anything!
Posted by stef.salmon at Oct 25, 2018, 9:22:10 AM
I guess there are no glass doors?!
Posted by hansmex at Oct 25, 2018, 1:29:14 PM
Did you look here ?
Posted by stef.salmon at Oct 25, 2018, 5:19:42 PM
No I didn't, thanks Hans.
Posted by stef.salmon at Oct 25, 2018, 5:31:23 PM
I have downloaded this door:
https://3dwarehouse.sketchup.com/model/7fa164...59747c64eb1311/glass-door
Is there a way of getting it to appear 45 degrees open?
Posted by UbuntuBirdy at Oct 25, 2018, 5:46:06 PM
It's a frameless door, so turn it for 45° and place it where it should be...
If the cutout in the wall does not fit, place a single frame from the lib where the cutout should be.
Pascal
Posted by stef.salmon at Oct 26, 2018, 9:49:05 AM
Thanks UbuntuBirdy.
I tried this and it did work...sort of. Why doesn't the door snap to the wall like the doors from the library?
Isn't there an easier way of using an existing door from the library and then changing the material to glass?
Posted by okh at Oct 26, 2018, 1:53:04 PM
Maybe because the door/window option was not selected on import(?)
Anyway, a glass door is a good model for testing hinges, frosted glass, cutout and 2D door-opening indicators..
Here is a quick example in SF 3d models 508
glass_door_hinged_cutout_plain.sh3d
Posted by stef.salmon at Oct 26, 2018, 7:10:56 PM
Yes it was a problem with the way I'd imported it, thanks.
