Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Draw Round Column |
| Print at Aug 22, 2026, 12:18:17 AM | |
| Posted by stef.salmon at Sep 28, 2018, 6:24:34 PM |
Draw Round Column Hi, This has probably been asked before...how can I draw a small circle to use as a column? Why isn't there a tool to draw circles and ellipses? Many thanks. |
| Posted by ndorigatti at Sep 28, 2018, 6:47:26 PM |
Re: Draw Round Column You can use cylinder object! |
| Posted by stef.salmon at Oct 4, 2018, 11:17:22 AM |
Re: Draw Round Column Hi, Cylinder object from where? |
| Posted by bdfd at Oct 4, 2018, 11:44:37 AM |
Re: Draw Round ColumnHi, Hi,Cylinder object from where? It's a standard object made by Emmanuel ! . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hansmex at Oct 4, 2018, 12:07:44 PM |
Re: Draw Round Column 1 - draw two walls which start and end at the same coordinates. 2 - give one wall an arc of 180 degrees, the other of minus 180 degrees. or look here ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Oct 4, 2018, 12:29:42 PM |
Re: Draw Round Column The cylinder object can be found in the Miscellaneous category. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stef.salmon at Oct 4, 2018, 12:57:02 PM |
Re: Draw Round Column Perfect...thank you all for your replies ![]() |
Current timezone is GMT Aug 22, 2026, 12:18:17 AM |
