Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: NegativeAllow the elevation of the object to be negative! |
| Print at Oct 17, 2026, 5:36:56 PM |
| Posted by harbinger at Jul 7, 2020, 10:15:41 PM |
Re: NegativeAllow the elevation of the object to be negative! Bumping this to keep this feature request alive. With many of my architectural plans, ceilings are lower in different rooms but much lower than the height of the level and so I put in soffits to account for the ceiling space in the shorter rooms. The problem is, since we can't put in a negative elevation, i have to elevate it on the lower level. When I then preview that level, the ceiling soffit shows up on the lower floor and I can't see the wall layout of that floor. If I could apply a negative elevation to a soffit which is being used to block off a ceiling, I could assign it to the floor above so that the soffit doesn't block the view. |
| Posted by crackwood01 at Oct 29, 2020, 11:50:25 AM |
Re: NegativeAllow the elevation of the object to be negative! I truly agree! So much time i've asked myself: why can't the object be negative elevation????? ---------- J'appuie TOTALEMENT cette fonctionalité. Il serait beaucoup plus simple de pouvoir donner une élévation négative que de créer des niveaux inutiles. |
| Posted by gregoryx at Nov 4, 2020, 12:53:51 AM |
Re: NegativeAllow the elevation of the object to be negative! Just tried to do this today... would have been nice. 👍 |
| Posted by infoboy2u at Mar 8, 2021, 6:09:37 PM |
Re: NegativeAllow the elevation of the object to be negative! Yes to this! BUMP! |
| Posted by Xiste at Mar 21, 2021, 9:30:51 PM |
Re: NegativeAllow the elevation of the object to be negative! I join the bump! Negative elevation would be a real time saver. |
| Posted by crackwood01 at Apr 13, 2021, 3:20:23 AM |
Re: NegativeAllow the elevation of the object to be negative! It's gonna be a bumpy ride .... ;)) |
| Posted by Gildaniel at Apr 14, 2021, 3:52:48 PM |
Re: NegativeAllow the elevation of the object to be negative! Usefull function, as far as wall elevation |
| Posted by Puybaret at Apr 14, 2021, 4:20:17 PM |
Re: NegativeAllow the elevation of the object to be negative! I’m not sure that negative elevations of furniture will happen, but sorry, don’t hope for wall elevation. If levels behave a little like layers, they are not layers. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 17, 2026, 5:36:56 PM |
