Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: New Wishlist |
| Print at Oct 17, 2026, 5:51:22 PM | View all posts in this thread on one page |
| Posted by harbinger at Sep 17, 2018, 6:27:29 PM |
New Wishlist This is the new grab bag of wishes first started here . Our esteemed dev has seen fit to listen to our prayers and incense, and i hope will find favor in his eyes.... OHHHMMMMM.... Input Custom Mouse Actions Many of us are used to other 3D applications and we've gotten used to the mouse behaving in a certain way. To help flatten the learning curve, it would help if the Mouse Actions could be customized to the given functions, separately in the 2D window and the 3D View. Displayed Mouse Coordinates It would help to see exactly where in the floor plan the mouse cursor is located, to help with starting room points and polylines for example. This could be displayed in the Status bar at all times, if the option is enabled. 15° Constrain in Move/Copy I often work not in 90° or even 45° increments; ideally we should have the option to Move or Copy items in 15° constraints. Custom Keyboard Shortcuts Working with Sweet Home would be more efficient if we have the option to define our own keyboard shortcuts. It would also be valuable if the more common plugins had their own as well. View Highlight Selection in 3D View Orientating our view would be easier if we had the option to highlight the given selection in the 3D View. Ideally we should be allowed to customize the color of the highlight. Wall View One of the most important features we'd like to see is the Wall View of a given wall. It makes it easier for real world dimensioning and visualization. One would have the choice when selecting a wall whether to look at it from the left or right, and be allowed to draw polylines and dimension lines on the resulting view. Reset Origin at Mouseclick A contextual menu option would allow the mouseclick to be set to the origin of the grid (0,0). Basically this moves all the elements in a relative amount so that the mouseclick is 0,0. Level Draw Option on other levels There should be options to allow the selected level to be drawn on all levels, those above, those below, or only the same elevation. Here's how it might look in an improved Modify Level dialog window. Remember Dialog Locations SH3D should remember dialog window locations. When we move them, we are moving them for a reason. Polylines Autoshapes Aiding in the floorplan development of SH3D, template polyline shapes, perhaps in SVG format, would be importable. Perhaps SH3D could keep a separate folder for these shapes, and like other Polylines, they could appear in 3D View (and in the proposed Wall View) if so chosen. Custom Polyline Display per Level Like Level Draw, Polylines would have the option to display on all, above, below, or same levels. Control Polyline Segments When drawing Polylines with multiple segments, it would be great if we could manipulate the segments of the Polyline shape. Half-Arrow Line Ending A common technique in floor plans are the indicator lines with half-headed arrows. Can this be added to the list of arrow endings for Polylines? ![]() Rooms/Walls Custom Wall Autocreation Method When you double-click a defined room while in the Wall Creation mode, the walls are auto-created along the room edges. I would love to be able to define how the walls are created — with the walls' surfaces formed inside, outside, or centered on the room edges. Un-join Walls Many times i wanted to split a wall to introduce another element or have the wall follow another path. The only way to do this is to Split the wall in two places, then delete the middle section, then retrace one of the wall segments the way i wish. Can't we just have one command in the contextual menu to simply put a break in the wall segment at the mouseclick? Lighting Unlit Textures I would love to be able to flag any texture of a surface or in a material as "unlit" — that is, unaffected by the lighting algorithm and showing at its normal brightness in the 3D View. Grouped Light brightness We still don't have the ability to change the power of Grouped lights all at once. Custom Light Types I would love to have the ability to have different light types in the Photo/Video creation — namely, normal, non-incidental, spotlight, and shaped lights. Non-incidental lights do not factor the angle of objects in the brightness. Shaped lights can project a light shape from the source. Custom Light Color/Strength Custom-colored lights would help with ambience, while light "Strengths" can be defined by an equation, such as sin(x), sqrt(x), or tan(x), where x is the brightness at a given distance. Photo/Video Video Animations When creating videos, it would be great if we could account for animations, like a fire in a fireplace or a swaying tree (done thru gifs or movs). Later it would allow us to incorporate a moving sky or human model animations. Furniture Sort Furniture List by more than one index In some applications, the sorting index remembers the order of how you want a list sorted. The Furniture list would be easier to use if we could incorporate this. For example, click once on the Name column header, then everything is sorted alphabetically. Click again on the Visible column header, then everything is sorted first by the Visibility toggle, then second alphabetically. And so on. Allow alternate color for furniture import When previewing an icon both in furniture import and the furniture tree, a white object is completely hidden in the white background of the preview box. This color should be customizable. Custom Furniture Icons in 2D View Any piece of furniture should have a customizable icon that can be placed in the 2D view. This would make it easier to visualize a floor plan or simplify a CPU-hungry model. This icon can be listed as an element of the furniture model data, perhaps in a folder pathname. Preferences Sorted Preferences In an effort to reduce the complexity of options, the Preferences window should be sorted and tabbed. This would make it easier to locate options, as well as make room for a "Help field," which would give assistance on what an option does for the SH3D experience. Here are some possible Preference tabs, with a few of the wishes listed here as examples: Feet-Decimals Measurement A sorely obvious missing feature, we Americans would love the option to have measurements show in Feet-Decimal format. Misc Editing Pivot Points for Rotation Vital for any 3D program, the ability to rotate an object around a defined pivot point. SH3D could remember the pivot point for any piece of furniture in its own table, and we would have the option to reset it to the centerpoint of the model. |
| Posted by hansmex at Sep 18, 2018, 12:03:24 PM |
Re: New Wishlist Excellent suggestion! ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by YGYL at Sep 18, 2018, 2:31:43 PM |
Re: New WishlistUnlit Textures Custom Light Types Custom Light Color/Strength Photo/Video Video Animations Let me say a few words. 1.sweet Home 3D is a software that is biased towards modeling, not rendering. Usually I export OBJ to other rendering software.No need to set any lights 2.If you want to render in sweet Home 3D, Custom Light Types/Custom Light Color, can be solved by other methods. ![]() Adding glass to the front of the light source can change the color of the light. ![]() |
| Posted by harbinger at Jul 30, 2020, 8:37:04 AM |
Re: New Wishlist Addendum 7/30/20 Option to Continue walls at Same Height as Source Wall When continuing a wall from the endpoint of another wall, the user should have the option to draw the wall at the same height and perhaps with the other attributes (texture, shininess, etc) as the wall that holds the endpoint, instead of the default assigned in Preferences. This is especially useful when i'm using wall drawing as a means of creating shapes (before exporting to OBJ) -- the height of the wall may not be the default height (assigned in Preferences). Perhaps when a modifier key is pressed when starting to draw a wall from another wall's endpoint, the source wall's attributes are assigned to the new wall when the wall-drawing is stopped. Ignore Textures in Displays When viewing the floorplans esp. with the 3D window open, the more textures you have, the more it slows down the view as the camera moves. This is especially problematic when you're making fine edits to dimensions of objects but the display only updates once every half or whole second. I'd love to be able to toggle the view so the textures aren't drawn on any furniture or structural components, in both the 2D and 3D views. A keyboard shortcut would be the best way to quickly turn it off or on. Cornices Just like baseboards, i think cornices at the tops of walls where they meet the ceilings would be a nice feature for SH3D, and would eliminate a lot of guesswork and superfluous furniture. Of course, cornices should be measured from the top of a wall and should be independent of the ceiling structure. I'm especially needing this automatic addition in curved walls. At first, perhaps a simple triangle or block extrusion along the top of the wall should suffice, but accomodation should be made in the program's data structure so that future versions allow for custom-shaped cornices. |
| Posted by harbinger at Sep 30, 2020, 11:06:43 PM |
Re: New Wishlist Unlit Textures I would love to be able to flag any texture of a surface or in a material as "unlit" — that is, unaffected by the lighting algorithm and showing at its normal brightness in the 3D View. I need this feature to show TV screens, elevator buttons, and appliance readouts that are lit but would not neccesarily be considered a light source. After doing some research on the MTL standard, I thought it would be possible using the "illum 0" statement in an OBJect's MTL file, but after doing some testing with this and the Ka, Kd, and Ks values, i still can't get unlit surfaces. I think its gonna take a code tweak to make textures unlit. Perhaps, Emmanuel, we could have SH3D use the "illum 0" statement for a special rendering trigger, in that the renderer does not apply light sources to the unlit surface, but just draws the texture image or color as is... |
| Posted by Puybaret at Sep 24, 2023, 5:35:29 PM |
Re: New Wishlist - A unit showing Feet with decimals was added to version 7.0. - The ability to highlight selection in the 3D View (and more) was added to version 7.2 when Selection and editing in 3D view option is selected in the preferences pane. - Customizing furniture icons in 2D View can be performed with the planIcon property which can be activated in Furniture Library Editor 2.0. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by tylla at Mar 14, 2024, 11:13:56 AM |
Re: New Wishlist - Allow alternate color for furniture import I would suggest implementing (as an option or as default) a checkerboard pattern as background. This would make any object stand out even if it has some special coloring. |
| Posted by Daniels118 at Mar 15, 2024, 10:13:04 AM |
Re: New Wishlist Wall view, vertical polylines and vertical dimension lines can all be addressed with existing plugins: Pan 3D view Wirings 3D dimension lines |
Current timezone is GMT Oct 17, 2026, 5:51:22 PM |
