Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) |
| Print at Aug 21, 2026, 9:42:44 PM |
| Posted by YGYL at Sep 26, 2018, 10:21:18 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)Pre-segmented dynamic object system is like this GIF picture. gif file |
| Posted by YGYL at Sep 27, 2018, 6:29:07 AM |
Water pipes and electric wiresWater pipes and electric wires Download the file Water_pipes_and_electric_wires.sh3d 2D vertical 2D view 3D view 3D detail ![]() |
| Posted by bdfd at Sep 27, 2018, 9:41:13 AM |
Re: Water pipes and electric wires Water pipes and electric wires Hi,... Good idea ! In France, all electric network is in the ceiling. It's easier to access and it avoids flooding … . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by YGYL at Sep 27, 2018, 2:17:49 PM |
Woods and grass Woods and grass Download the file Woods_and_grass.sh3d 2762 grass objects with different directions and sizes 2D top view 3D view Trees with different directions Rendered graph |
| Posted by YGYL at Sep 27, 2018, 2:30:05 PM |
Re: Woods and grass If you don’t have a random distribution system, it takes a lot of time to do this kind of map. If you can randomly distribute the specified multiple objects, including Random location within range Random size within range Random direction or both directions Range random machine height Well, doing this is very fast. |
| Posted by YGYL at Oct 13, 2018, 2:14:21 PM |
Re: Woods and grass My thoughts on Pre-segmented dynamic object system's custom user interface Allow advanced user defined material library It also provides ordinary users to define him in software. This will be a great pleasure for software. I hope users can create some interesting things when using software. So there is no need for too many restrictions. The whole process is reflected in a Script form. The software executes some items on the table down. If set correctly, those cases in my front post will be reached. After execution, a new object is generated in the object bar. Drag and modify this new object to automatically create complex objects. Script form Type is the most important column.Determines the function of this script.Other columns are his parameters. left Middle (simple) Pattern 1 Pattern 2 Pattern 3 Right corner Inner corner Outer corner Random placement (square) Random layout (circle) Several choices 1 (Book) Intermittent repetition blank |
| Posted by VeroniQ at Jan 30, 2019, 12:01:18 AM |
Re: Woods and grass Thank you very much, YGYL, for these models that I may use in a “Haussmanian” flat. Could you confirm that the 3D models listed on this page are available under Free Art Licence or CC-BY Licence? Thanks in advance |
| Posted by Bubblobill at Jun 22, 2019, 10:39:32 AM |
Re: Woods and grass I've been considering something similar based on a staircase constructing plugin. |
Current timezone is GMT Aug 21, 2026, 9:42:44 PM |
