Print at Jul 22, 2026, 1:21:11 AM View all posts in this thread on one page
Posted by Kunda at Aug 4, 2018, 2:37:05 AM
Misc typo fix patch
Patch cleans up some typos in the code.
Can be applied with:
patch -p0 < sweethome3d-typos.patch
diff --git trunk/SweetHome3D/build.xml trunk/SweetHome3D/build.xml
index ea94089a4..87103f936 100644
--- trunk/SweetHome3D/build.xml
+++ trunk/SweetHome3D/build.xml
@@ -27,7 +27,7 @@
- sourceArchive : Builds SweetHome3D-version-src.zip file in install directory
- javadoc : Builds SweetHome3D-version-javadoc.zip file install directory
- - jdepend : Launchs a JDepend graphical UI to help update dependencies in PackageDependenciesTest
+ - jdepend : Launches a JDepend graphical UI to help update dependencies in PackageDependenciesTest
<project basedir="." default="jarExecutable" name="SweetHome3D">
<!-- The current version of Sweet Home 3D -->
@@ -1382,9 +1382,9 @@
<echo message="install/SweetHome3D-${version}-javadoc.zip ready for ftp"/>
</target>
- <!-- Launchs a JDepend graphical UI to help update dependencies in PackageDependenciesTest test -->
+ <!-- Launches a JDepend graphical UI to help update dependencies in PackageDependenciesTest test -->
<target name="jdepend" depends="build"
- description="Launchs a JDepend graphical UI">
+ description="Launches a JDepend graphical UI">
<!-- Create jdepend.properties file in build directory that specifies ignored Java packages -->
<concat destfile="build/jdepend.properties">ignore.java=java.*</concat>
diff --git trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java
index 69816c441..d649fb800 100644
--- trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java
+++ trunk/SweetHome3D/src/com/eteks/sweethome3d/applet/HomeAppletRecorder.java
@@ -171,7 +171,7 @@ public class HomeAppletRecorder implements HomeRecorder {
URLConnection connection = null;
DefaultHomeInputStream in = null;
try {
- // Replace % sequence by %% except %s before formating readHomeURL with home name
+ // Replace % sequence by %% except %s before formatting readHomeURL with home name
String readHomeURL = String.format(this.readHomeURL.replaceAll("(%[^s])", "%$1"),
URLEncoder.encode(name, "UTF-8"));
// Open a home input stream to server
@@ -278,7 +278,7 @@ public class HomeAppletRecorder implements HomeRecorder {
HttpURLConnection connection = null;
try {
String deletedHomeURL = String.format(this.deleteHomeURL.replaceAll("(%[^s])", "%$1"),
// Send request to server
diff --git trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java
index 596cd74be..e7f8e3c97 100644
--- trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java
+++ trunk/SweetHome3D/src/com/eteks/sweethome3d/io/Base64.java
@@ -453,7 +453,7 @@ public class Base64 {
* anywhere along their length by specifying
* <var>srcOffset</var> and <var>destOffset</var>.
* This method does not check to make sure your arrays
- * are large enough to accomodate <var>srcOffset</var> + 3 for
+ * are large enough to accommodate <var>srcOffset</var> + 3 for
* the <var>source</var> array or <var>destOffset</var> + 4 for
* the <var>destination</var> array.
* The actual number of significant bytes in your array is
@@ -785,7 +785,7 @@ public class Base64 {
- * are large enough to accomodate <var>srcOffset</var> + 4 for
+ * are large enough to accommodate <var>srcOffset</var> + 4 for
* the <var>source</var> array or <var>destOffset</var> + 3 for
* This method returns the actual number of bytes that
diff --git trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java
index c9be41efb..ae0cc909c 100644
--- trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java
+++ trunk/SweetHome3D/src/com/eteks/sweethome3d/model/Room.java
@@ -80,7 +80,7 @@ public class Room extends HomeObject implements Selectable, Elevatable {
public Room(float [][] points) {
if (points.length <= 1) {
- throw new IllegalStateException("Room points must containt at least two points");
+ throw new IllegalStateException("Room points must contain at least two points");
this.points = deepCopy(points);
this.areaVisible = true;
@@ -319,7 +319,7 @@ public class Room extends HomeObject implements Selectable, Elevatable {
if (index < 0 || index >= this.points.length) {
throw new IndexOutOfBoundsException("Invalid index " + index);
} else if (this.points.length <= 1) {
- throw new IllegalStateException("Room points must containt at least one point");
+ throw new IllegalStateException("Room points must contain at least one point");
float [][] newPoints = new float [this.points.length - 1][];
