Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: An error installing the lastest version |
| Print at Jul 12, 2026, 7:51:53 AM | |
| Posted by antonioperez2002 at Jul 24, 2018, 12:36:25 PM |
An error installing the lastest version This happened with the previous version too. Look at the screenshoot. What should I do? Thank you so much!! http://www.mediafire.com/view/887e9izzhxxmq4p/Sin_t%25C3%25ADtulo.jpg/file My PC : Lenovo ThinkPad x201 tablet x64 bits. Graphic card : Intel . Windows 10 Pro Education |
| Posted by UbuntuBirdy at Jul 24, 2018, 5:17:52 PM |
Re: An error installing the lastest version You can find the solution at the FAQ section of this Website: How can I adjust the memory used by Sweet Home 3D? Sweet Home 3D can't use as much as memory as your computer can offer by itself, but you can still change the maximum memory used by the program if needed. This may be required for example if an error red cross appears during the photo rendering of a home with many different and detailled 3D models. By default, the Java Web Start version uses 640 MB or 2 GB at maximum according to your system, and the installer version uses 1 GB or 2 GB at maximum, except under 32-bit Windows where it's still 640 MB (this maximum is displayed in the About dialog box). For the installer version, you can change this number by udpating the value of the -Xmx Java option, as follows:
---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Jul 12, 2026, 7:51:53 AM |
