Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Balcony Issue |
| Print at Jul 12, 2026, 8:52:04 AM | |
| Posted by Amerigo at Jul 24, 2018, 1:30:07 AM |
Balcony Issue I have made a balcony .obj. If it is set to be a door/window, then it connects to the wall, but it's depth is changed to 0"3" when it should remain at 6'. If set to be movable, stairs, or nothing, then it looks right but doesn't connect to the wall. If someone can take a look, you can download from here . |
| Posted by Puybaret at Jul 25, 2018, 3:01:35 AM |
Re: Balcony Issue You could import it as a door or window, then place it with magnetism deactivated. But this won't solve your problem completely because the cutout in the wall will be incorrect. The easiest way should be to import the elements of your balcony independently from the others. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 12, 2026, 8:52:04 AM |
