Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Modify the materials of a piece of furniture |
| Print at Aug 25, 2026, 11:16:25 AM | View all posts in this thread on one page |
| Posted by enkonyito at Jul 17, 2018, 12:47:18 AM |
Modify the materials of a piece of furniture In the HomeMaterial class , only methods for obtaining information about the color, name, shininess, or texture of a material are defined. Is it possible to change the value of these parameters other than by manually accessing the Home.xml file? When there is more than a hundred pieces of furniture, it's tiring. ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Jul 17, 2018, 1:35:12 AM |
Re: Modify the materials of a piece of furniture HomeMaterial objects are immutable like a few other ones in Sweet Home 3D like BackgroundImagel, Sash, TextStyle... instances. But I guess your question isn't about the advantages of immutability, right? As you're a programmer, you could call the setModelMaterials in HomePieceOfFurniture class with a new array of HomeMaterial instances. What is the problem to do that? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Jul 18, 2018, 3:58:02 AM |
Re: Modify the materials of a piece of furniture HomeMaterial objects are immutable like a few other ones in Sweet Home 3D like BackgroundImagel, Sash, TextStylel... instances. But I guess your question isn't about the advantages of immutability, right? No, I didn't know the advantages of immutability .As you're a programmer, you could call the setModelMaterials in HomePieceOfFurniture class with a new array of HomeMaterial instances. What is the problem to do that? Sometimes we miss out on the most obvious things.I had not yet figured out how to use this method in my plugin. Thanks ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Jan 9, 2019, 12:40:32 AM |
Re: Modify the materials of a piece of furniture Is it normal that sometimes the getModelMaterials() method only returns one material when there are several? ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Jan 24, 2019, 10:13:44 PM |
Re: Modify the materials of a piece of furniture It's normal and I was able to adapt it to my plug-in. ![]() ---------------------------------------- EnkoNyito |
Current timezone is GMT Aug 25, 2026, 11:16:25 AM |
