Print at Oct 15, 2026, 5:41:43 AM
Posted by spalme77 at Jul 8, 2018, 2:59:26 PM
Saving paths for video
Hi all,
I am quite new to SweetHome3d (and I love it, btw), so maybe I just have not found how to do what I want...
I am creating small "walk-through" videos for different parts of my plan. I have not yet found a way to save the walk-through path somehow, so whenever I want to to re-render something (maybe because of new furniture, new lights, whatever), I have to recreate the path manually, which is 1) tedious work, and 2) does not guarantee the same path as used in previous renderings.
Any hints how to solve this issue?
Thanks and regards!
-stefan-
Posted by Puybaret at Jul 9, 2018, 1:52:01 AM
Re: Saving paths for video
Unless you're ready to edit the Home.xml entry in the saved SH3D file by hand, there's no way to edit the points of the path. If your path doesn't contain too many points, you could also store each point of view and restore them one by one.
Posted by spalme77 at Jul 9, 2018, 8:23:02 AM
Would it be enough to fiddle around with Home.xml (more concrete with the entries /home/environment/observerCamera[attribute='cameraPath'])?
I am going to create some tooling to extract/insert these XML tags to save/restore my paths. I hope there is nothing in the binary file 'Home' required for this to work - is there?
Thanks and regards
-stefan-
Posted by Puybaret at Sep 6, 2018, 1:38:32 PM
When present, the priority is given to the Home.xml entry and the Home entry is ignored. You can even remove Home entry, it's still in a SH3D file for backward compatibility, and will disappear in a future version.
