Print at Aug 19, 2026, 9:56:27 PM
Posted by bdfd at Jun 2, 2018, 2:18:14 PM
confused   Light properties
who knows the name of the property to fix the brightness of a light source in the properties file named 'pluginFurnitureCatalog.properties' ?
confused
Posted by Puybaret at Jun 3, 2018, 2:40:22 AM
Re: Light properties
The property is lightSourceColor#..., fully black matching no light, and white #FFFFFF matching a white light at full power.
See DefaultFurnitureCatalog.properties for examples.
Posted by bdfd at Jun 3, 2018, 10:19:12 AM
Thank your for your return.
My ask has been not understand perhaps by using bad words, I wanted to say the power of lightsource (0 to 100%) and not the color. biggrin
I want to change the default value (50%) to 5% (for example).
but… I didn't see this in given file.
Posted by okh at Jun 3, 2018, 9:11:16 PM
You can find all the properties in DefaultFurnitureCatalog.PropertyKey.html.
You will, as indicated by Puybaret, need to adjust RGB down in sync. The power is, however, saved in Home.xml, as that reflects the adjustment made by the user in the design.
Posted by bdfd at Jun 4, 2018, 8:19:30 AM
Great !
Do you know how to update this data in a sh3f file ?
biggrin
Posted by Puybaret at Jun 4, 2018, 1:36:48 PM
Use a zip utility to extract the PluginFurnitureCatalog.properties file from a SH3F file and rezip it at the end, and a text editor to edit the PluginFurnitureCatalog.properties file.
Posted by okh at Jun 4, 2018, 1:51:52 PM
Sorry if I was unclear. There is no power setting in .sh3f/PluginFurnitureCatalog.properties (only in .sh3d/Home.xml). In .sh3f/PluginFurnitureCatalog.properties you can use the html (six digit hex) colour notation:
a very bright white light would be:
lightSourceColor#xxx=#FFFFFF
a 'normal sh3d white' lightsource is (if I remember):
lightSourceColor#xxx=#BBBBBB
a much less bright 'white' light would be:
lightSourceColor#xxx=#222222
Posted by bdfd at Jun 4, 2018, 2:51:00 PM
TY okh.
Damned, a parameter only manually update. crying
Perhaps a adding to do in whislist section for next 5.8… wink
Posted by enkonyito at Jun 5, 2018, 2:03:47 AM
@bdfd
This is possible in a derived version of SH3D by modifying line 53 of the HomeLight.java file.
EnkoNyito
Posted by bdfd at Jun 5, 2018, 8:15:15 AM
@bdfd
TY enkonyito.
But I don't like this because it's "all or nothing"... biggrin
I explain : I want to update ONE object in a sh3f not all objects of same type in SH3D.
wink
