Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Grouping elements |
| Print at Sep 29, 2026, 10:21:04 AM | |
| Posted by ipfelkofer at May 3, 2018, 9:22:44 AM |
Grouping elements I have set up a kitchen and wanted to group all furniture elements. The result is not as I would like it to be. I have a cabinet, a ceramic hob on top of it and an upper cabinet above both. Ungrouped it is shown exact as it should. As soon as this becomes a group (or part of one) the ceramic hob is always shown on top of the upper cabinet. This applies to the twodimensional floorplan only. Did I make any mistake? |
| Posted by dorin at May 3, 2018, 3:39:55 PM |
Re: Grouping elements It's about the order to draw it.(Look in the furniture list) The order of insert is: lower cabinet, ceramic hob and upper cabinet. After grouping will look OK in both (2D & 3D). If You don't want to redraw all, You can use the cat and paste in same place until realize the needed order. The same are happen when You insert table before chairs and You want them partially under table. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by ipfelkofer at May 3, 2018, 4:59:48 PM |
Re: Grouping elements Thank you very much. Of course it works the way you described it! |
Current timezone is GMT Sep 29, 2026, 10:21:04 AM |
