Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Stop the walls from using CC |
| Print at Sep 29, 2026, 10:16:12 AM | View all posts in this thread on one page |
| Posted by MrGlad8 at Apr 29, 2018, 9:13:01 AM |
Stop the walls from using CC Hello! I like this program so far. But when I'm making walls of my room - I first take the measures in my room from the inside of course, thats what I'm interested for. So lets say my room in 100 x 100 cm If I then in the software start doing walls and I type 100x100x100x100 like a square the inside measures is 90x90x90x90 ? I guess that is because the software counts the measures from the CC of the wall, whatever thickness it is. How come? I'm only interested in talking the measures inside the room, or why do I want to invole the CC measure of the walls? Can I change this somehow? Very annoying so far. |
| Posted by Puybaret at Apr 29, 2018, 9:38:52 AM |
Re: Stop the walls from using CC Hello, Walls are measured in their middle as you noticed and this can’t be changed. This subject has been discussed many times in the past: as there’s no way to guess how users will draw the next walls, there are many situations where measuring the length of wall side wouldn’t be reliable. So either you take into account the thickness of the walls when you draw them, or you draw a room first with the Room creation tool, then add walls around it with a double click in it with the Wall creation tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MrGlad8 at Apr 29, 2018, 10:15:59 AM |
Re: Stop the walls from using CC Hello, Walls are measured in their middle as you noticed and this can’t be changed. This subject has been discussed many times in the past: as there’s no way to guess how users will draw the next walls, there are many situations where measuring the length of wall side wouldn’t be reliable. So either you take into account the thickness of the walls when you draw them, or you draw a room first with the Room creation tool, then add walls around it with a double click in it with the Wall creation tool. thank you! that double-clicking a created room worked great! Oh by the way, when doing doors I see it have a baseboard. Is the width of the door including those baseboard that show up in the 3d-view? |
| Posted by Puybaret at Apr 29, 2018, 3:49:52 PM |
Re: Stop the walls from using CC If by baseboard of a door, you mean the frame around it, yes, it includes it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MrGlad8 at Apr 29, 2018, 6:29:04 PM |
Re: Stop the walls from using CC If by baseboard of a door, you mean the frame around it, yes, it includes it. OK thank you. Another problem. If I for example make 2 rooms next to each other using "Create Rooms-tool" and then decide to add walls to them by double-clicking the room walls with go in to each other.. eh? What am I doing wrong? |
| Posted by Puybaret at Apr 29, 2018, 7:14:54 PM |
Re: Stop the walls from using CC "with go", do mean "will go", or that walls be superimposed? From version 5.5, only missing walls should be created, but you should rather alternate between room drawing and wall creation, i.e draw a room, create walls around it, draw the second room beside the walls of the first room and create walls around the second room, etc ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 10:16:12 AM |
