Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Opaque window |
| Print at Oct 1, 2026, 8:44:11 AM | |
| Posted by bdfd at Apr 26, 2018, 8:17:38 AM |
Opaque windowHi, how to make an opaque glass ? ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Apr 26, 2018, 4:23:48 PM |
Re: Opaque window By "opaque", do you mean the glass should let some light go through, but without being able to distinguish objects being the glass? Not sure it's really possible in Sweet Home 3D, but you can try with some glass textures on some transparent material, like in this video at 3'05". ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Apr 26, 2018, 6:42:25 PM |
Re: Opaque window By "opaque", do you mean the glass should let some light go through, but without being able to distinguish objects being the glass? Yes, exactly !Not sure it's really possible in Sweet Home 3D, but you can try with some glass... I did many tries without success. ![]() An idea : I read this morning a fetaure of enko on light about a vertical surface... but how make this object ? ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Golia at Apr 26, 2018, 10:46:56 PM |
Re: Opaque window Hello, if I understand correctly you want to adjust the transparency of an object I'm going to change the mtl property of the obj file is this what you're interested in? translated google |
| Posted by Golia at Apr 26, 2018, 10:50:03 PM |
Re: Opaque window newmtl Glass illum 1 Ka 0.0 0.0 0.0 Kd 0.5019608 0.49803922 0.49803922 Ks 0.0 0.0 0.0 Ns 1.0 Ni 1.0 d 0.9 <---- opaque newmtl Glass illum 1 Ka 0.0 0.0 0.0 Kd 0.5019608 0.49803922 0.49803922 Ks 0.0 0.0 0.0 Ns 1.0 Ni 1.0 d 0.2 <---- transparent |
| Posted by bdfd at Apr 27, 2018, 9:37:56 AM |
Re: Opaque window Hello, if I understand correctly you want to adjust the transparency of an object Hi Golia,I'm going to change the mtl property of the obj file is this what you're interested in? translated google It was a good idea but no ! I explain : I did that you said with the mtl file (d 0.975 ). Directly under sh3d, Yes with a outside screenshot ! Look at the left side... --------------------------- But in standard rendering... ![]() Outside and without light, opaque propertie has disappeared. --------------------------- Outside and With light, no difference. --------------------------- Inside without light, no difference ! --------------------------- Inside with light, same result ! Thank you for your idea but it's not positive... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Oct 1, 2026, 8:44:11 AM |
