Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: kitchen countertops ? |
| Print at Jul 27, 2026, 4:35:46 PM | View all posts in this thread on one page |
| Posted by dlbrum at Mar 15, 2018, 10:24:45 PM |
kitchen countertops ?Likely a silly noob question, but how does one make countertops ? Like a kitchen island sort of thing ? Merci beaucoup... |
| Posted by bdfd at Mar 16, 2018, 7:53:34 AM |
Re: kitchen countertops ? There are some by default in the 'kitchen' category. Otherwise you can either do it yourself with some boxes, either import it from 3dwharehouse site ... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hansmex at Mar 16, 2018, 9:25:32 AM |
Re: kitchen countertops ? - Draw a wall or several walls that have the shape of the desired counter top - Insert invisible box or cylinder to cut out the shape of sink or stove - Apply colour(s) or texture(s) - Select your design, then export the selection - Import it as a model and rotate 90 degrees for desired porition ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by dlbrum at Mar 17, 2018, 12:42:53 AM |
Re: kitchen countertops ? Thanks ! |
| Posted by VintageJim at Apr 1, 2018, 4:19:31 PM |
Re: kitchen countertops ? I have done countertops with boxes made 1 1/2" high and 25" deep. Trying to wrap my head around your technique. What are you applying the color/texture to? The walls? The floor? Why rotate 90ยบ? I think my brain is too stuck in actual kitchen design software to visualize your technique. Comes from nearly 20 years of using 20/20 kitchen design software. ![]() |
| Posted by hansmex at Apr 1, 2018, 5:48:40 PM |
Re: kitchen countertops ? Countertops usually have one or more holes in them for sink and/or stove. There are two ways to make holes using SH3D: 1 - in walls using the door/window feature. 2 - in floors/ceilings using the stairs feature. Both methods have their (dis)advantages. If you've been using kitchen design software for 20 years, it might be best to stick to that software. It's probably better geared towards that specific task than SH3D. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by VintageJim at Apr 6, 2018, 2:58:40 PM |
Re: kitchen countertops ? If you've been using kitchen design software for 20 years, it might be best to stick to that software. It's probably better geared towards that specific task than SH3D. Changed jobs... no longer have access to 20/20 Design. Only do a handful of kitchens now rather than hundreds of them. Thanks for your reply. |
| Posted by susieque at May 15, 2018, 12:07:03 AM |
Re: kitchen countertops ? There is a "Shelf Maple" in the Bedroom List that I used as a countertop, you just need to figure out the elevations and textures. When you double click the item, click on the "textures" tab and scroll down to Miscellaneous and you'll find granite and marble finishes that can be used. |
| Posted by digitaltrails at May 20, 2018, 5:32:16 AM |
Re: kitchen countertops ? I use groupings of boxes which I size and then texture and group with the standard kitchen furniture shipped with SH3D. I can make a hole for a sink by making that part of the counter out of several boxes surrounding the hole. In my case the counter was engineered stone with the surface options all being small granular textures. I guess multiple boxes might not be a technique for textures with larger grain. It would be useful if SH3D came with a standard set of primitive shapes, such as boxes, prisms, pyramids, and a thin walled open-top open-bottom box. It would then be easy to create a variety of counter tops, slopes, roofs, etc, without resorting to Art of Illusion or other such tools. If the sides of all primitives had a separate material that would also be very helpful (it would be easier than laminating with more boxes). Here is a SH3D rendering of kitchen where boxes contribute to the counter-top, cabinet panelling, light fittings, cabinet handles, etc: ![]() And then we actually constructed it: ![]() All in all, SH3D prevented many mistakes and helped guide the whole effort as we worked our way through the entire house. |
| Posted by bdfd at May 20, 2018, 9:01:05 AM |
Re: kitchen countertops ? I use groupings of boxes which I size and then texture and group with the standard kitchen furniture shipped with SH3D. I can make a hole for a sink by making that part of the counter out of several boxes surrounding the hole. In my case the counter was engineered stone with the surface options all being small granular textures. I guess multiple boxes might not be a technique for textures with larger grain. Yes, we did.It would be useful if SH3D came with a standard set of primitive shapes, such as boxes, prisms, pyramids, and a thin walled open-top open-bottom box. It would then be easy to create a variety of counter tops, slopes, roofs, etc, without resorting to Art of Illusion or other such tools. If the sides of all primitives had a separate material that would also be very helpful (it would be easier than laminating with more boxes). Entirely agree with you.Here is a SH3D rendering of kitchen where boxes contribute to the counter-top, cabinet panelling, light fittings, cabinet handles, etc: Amazing, I like this kitchen ! ![]() And then we actually constructed it: ![]() All in all, SH3D prevented many mistakes and helped guide the whole effort as we worked our way through the entire house. ![]() . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Jul 27, 2026, 4:35:46 PM |
