Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: measure and dimensions |
| Print at Oct 1, 2026, 8:44:13 AM | |
| Posted by brodbdie at Mar 6, 2018, 1:07:01 PM |
measure and dimensions at the moment a roomsize is measured mid of a wall to mid of a wall. it would be helpful to change in the settings the measure method to border to border. If setting up a plan the base is the etsimate and this is based on inside dimensions. |
| Posted by Puybaret at Mar 7, 2018, 12:10:22 AM |
Re: measure and dimensions Hum, sorry if you find me a little rude, but this subject has been discussed so many times that I prefer to let you explore the forum to get a deeper explanation. By the way, objects called "rooms" are drawn corners to corners, then you can double click in them with the wall creation tool to draw walls around them. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 8:44:13 AM |
