Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: create sh3f library |
| Print at Aug 16, 2026, 5:41:40 AM | View all posts in this thread on one page |
| Posted by morellik at Feb 25, 2018, 8:27:18 PM |
create sh3f library I have a lot of objects to load in Sweet Home and I don't want to do it "one by one". Is there a program I can use to create a library sh3f ? Thank you. |
| Posted by Puybaret at Feb 25, 2018, 9:05:06 PM |
Re: create sh3f library Try the Furniture Library Editor. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by morellik at Feb 28, 2018, 6:29:33 PM |
Re: create sh3f library All OK, thank you. |
| Posted by Lesni at Oct 21, 2018, 11:01:53 PM |
Re: create sh3f library To use this Editor, must I install Java? My employer has restrictions on unauthorized programs. Is there a way to have this as a plugin rather than stand-alone. |
| Posted by Puybaret at Oct 22, 2018, 12:06:33 AM |
Re: create sh3f library You must have Java somewhere, installed with an installer or copied from elsewhere. The Furniture Library Editor doesn't exist as a plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Lesni at Oct 22, 2018, 4:17:35 AM |
Re: create sh3f library Thanks, I found the javaw in the bin folder. Using the command I can start it. :) |
| Posted by Lesni at Oct 22, 2018, 4:31:18 AM |
Re: create sh3f library In Sweet Home 3D I put an ini file to make the rows and columns readable. Is there one for this program also? |
| Posted by Puybaret at Oct 22, 2018, 10:31:25 AM |
Re: create sh3f library If you have a HiDPI screen, install Java 10 or 11. That will fix the issue. Note that the ini file used for this purpose with Sweet Home 3D isn’t necessary with version 6.0, and I’ll be happy to know how it works for you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dorin at Oct 22, 2018, 8:01:46 PM |
Re: create sh3f library If You've already import the furniture piece-by-piece (name are shown in italic), You could save all in a personal furniture library which could be loaded when needed. 1. Install the ExportToSH3F-1.0.sh3p plugin; 2. In menu: Furniture > Export imported furniture to SH3F... Note: Sometime You need to make fine adjustment in PluginFurnitureCatalog.properties file. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Aug 16, 2026, 5:41:40 AM |
