Print at Aug 15, 2026, 2:55:01 PM
Posted by richardlyons at Feb 2, 2018, 4:45:03 PM
ver 5.7 on Linux "Can't create graphics environment"
Installed 5.7 from the tgz 'SweetHome3D-5.7-linux-x64.tgz' and happily the program opens via 'SweetHome3D-Java3D-1_5_2', and runs 2D layout.
However there is no 3D rendering, and the following errors are logged on startup
$ /opt/SweetHome3D-5.7/SweetHome3D-Java3D-1_5_2
Java 3D: implicit antialiasing enabled
amdgpu_parse_asic_ids: Cannot parse ASIC IDs: Ressource temporairement non disponible
Exception in thread "AWT-EventQueue-0" javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D
at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.access$200(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:86)
at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:193)
at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:180)
at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179)
at java.awt.Component.processComponentEvent(Component.java:6365)
at java.awt.Component.processEvent(Component.java:6313)
at java.awt.Container.processEvent(Container.java:2237)
at java.awt.Window.processEvent(Window.java:2025)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2295)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
It is a generic AMD 64-bit box running Arch Linux. (The distro packaged version is only ver 5.6, and in any case does not run.)
Is this sufficient info to identify the problem?
TIA
Posted by Puybaret at Feb 2, 2018, 7:58:08 PM
Re: ver 5.7 on Linux "Can't create graphics environment"
And how works SweetHome3D script?
Posted by richardlyons at Feb 2, 2018, 8:48:03 PM
@Puybaret:
The Sweethome3D script opens only the splash screen and stops (as before, with 5.6).
Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped
at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2071)
at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1924)
at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875)
at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.j3)
at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230)
at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216)
at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1021)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050)
at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803)
at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicTemplate3D.java:317)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:207)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Sour
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObservewn Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
Posted by richardlyons at Feb 2, 2018, 9:56:25 PM
SOLVED!:
I have just discovered the problem is caused by the fact I use a tiling window manager. Switching to icewm, for example, I get full 3D functionality.
Posted by yatsek at Apr 9, 2021, 6:08:24 PM
This post shows on top of Google search when looking for mentioned error - i.e:
$ sweethome3d
This was not solved neither by using freshly downloaded version of SweetHome3D nor by running
./SweetHome3D-Java3D-1_5_2
But what was VERY helpful was (found on some other place in this forum) to add:
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
in script SweetHome3D
Posted by Gianca_UY at Aug 24, 2022, 4:54:54 AM
$ sweethome3d
I've just registered to thank yatsek because this worked (on v6.6.2 just in case)!!
